110 settings -- help
Username: Njc
advice please for a novice
I have 2 dishes. 119 & 110
I have the settings for echo 7 and when scanned I get all channels
But when I scan echo 8 I only get a few channels and i would dearly love to get FSC - 149
I have Pansat 3500, what settings should echo 8 be on in the antenna set up page?
Thank You in advance
Username: Tale
Post Number: 22
Try to blind scan individually ,without the switch and see what you get.After that set up the switch to correct LNB.The setup is the same as echo 7.
Username: Donnie1973
Post Number: 1769
echo 7 is disecq 1
echo 8 is disecq 2
dish pro lnb?
