CRKT1 and CRKT2 Channel ?
Username: Addtemp
Post Number: 10
I can't find Channel 703 and 708 on Nimiq 1,3 91
I did Scan them during the Match and has followed scanning different Tp some say 12501V other said 12370 V but No Luck.
I would Prefer to do Specific TP Scan rather then blind Scan.
Does Any one has the Correct TP frequency for these channels that they used recently.
Username: Ds_edm
Post Number: 88
do blind scan during match
Username: Ds_edm
Post Number: 89
fr. 12618
v6450 a6451 p6450 H 5/6
Username: Addtemp
Post Number: 11
Thanks ds I will give it a try next time these Channels are UP
Username: Saqeeb9000
Post Number: 109
or just do a blind scan that works too. channel number might be different...
Username: Addtemp
Post Number: 12
The Problem I am facing is that I have ViewSat Pro and it seems it duplicates channels and TPs if I do blind scan.
Username: Addtemp
Post Number: 13
Also I looked around and am not sure if any Satellite file exist for Vewsat Pro. Alos I have never used the Satellite file so am not sure how you update one either.
Username: Ds_edm
Post Number: 90
u are welcome. do all channel delete witn F3 for 91 before blind scan then you wont have duplicate channel
Username: Dj_asya
Montreal, Qubec Canada
Post Number: 29
does any one know why zee sports not working and how to fix when i go to the channel its says something like WAIT FOR KEY ROLL but at the same time the others chanels are working fine
ihave pansat 2500 convert 2700
SYSTEME INFORMATION
CLONE
SAFE:75-22OT_EUBX
BOOT VERSION:75
02.NOV.2007
TAHANKS IN ADVANCE BYE
Username: Dj_asya
Post Number: 31
what is the name of this channel could i have it if i have a pansat 2500 converted to 2700
and how plz tell me bye
Username: Ds_edm
Post Number: 97
they might have sifted channel to diffrent freq. try bliend scan with that
Username: Afaizi
Post Number: 33
i dont know if anyone would know the answer to this but is it possible to set the dish to 119 and get zee sports in edmonton?
Username: Ds_edm
Post Number: 102
scan now
