Bronze Member Username: Irky
Post Number: 15 Registered: Sep-07
Posted on what kind cable i need for pansat 2500 to download bin. |
Gold Member Username: Ryersonresurrected
CANADA Charlatan...
Post Number: 1064 Registered: Sep-06
Posted on |
Gold Member Username: Tapeman
New York City in-HD,
NY
Post Number: 1777 Registered: Oct-06
Posted on Plus one of these
CANADA Charlatan...
Post Number: 1068 Registered: Sep-06
Posted on |
Post Number: 16 Registered: Sep-07
Posted on th i think on this forum i can find help but you guys jouking whit me. |
Post Number: 17 Registered: Sep-07
Posted on can i use cable from pansat 3500sd for pansat 2500 for download bin. |
Silver Member Username: Ustaad_hc
Post Number: 347 Registered: Oct-06
Posted on |
Silver Member Username: Rtap
FL
Post Number: 888 Registered: Jan-07
Posted on Ariza Ultra 400/500- Null Astrovox 2600-Straight DB9 Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II, MS1000, ,etc.)-Null Co0lsat 4000 Plus-Null Co0lsat 4000 Pro-Straight DB9 Cooltec-Null Coship (All)-Null Digiwave 6800/7000-Null Digiwave Diamond-Straight DB9 Dreambox (All)-Null Fortec lifetime-Straight DB9 Fortec Lifetime Ultra-Straight DB9 Lava 2600-Null Max 2500-Null ****sat (All)-Straight DB9 Microroyal (All)-Null Pansat 2300a/2500a and all clones-Straight DB9 Pansat 2700-Null Pansat 3500-Null Pansat 5000HC-Null(Also can program through USB) Pantec/Multistar Max (All)-Null Pantec/Multistar MS (All except MS1000)-Straight DB9 Pantec MX/Ultra-Straight DB9 Rex1-Null Silver bullet/ST 1000/2000-Null Skyview 500-Straight DB9 Spacestar DVB500-null Stealth 2000a-Null Ultrastar 5000-Null Viewsat VS2000-Null List of Popular Receivers Firmware Cable NULL MODEM CABLE (Cross over ) * Ariza Ultra 400/500/700/750/800 & Extreme - Null modem cable * Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II. MS1000, ,etc.)- Null cable * Bluejay 1 & 2 -Null modem cable * Buzz S2010F - Null modem cable * Captive Works 1000s (CW500s,CW600s, CW600s Premium) - Null * Co0lsat 4000 Plus-Null * Cooltec ( Clones only ) - Null * Coship (All)-Null * Digiwave 6800/7000-Null * Dreambox (All)-Null * ExtremeView Magnam XV3300 - Null * Koolsat/Sonicsat (clone) - Null * Kusat Pro 2600a - Null * Lava 2600-Null * Max 2500-Null * Microroyal (All)-Null * Neusat SP6000 ( SP6000 Premium ) -Null (Also can program through USB) * Orasat v5- Null * Pansat 2700-Null * Pansat 3500s/sd - Null Cables - (Also SD Memory Card) * Pansat 5000HC-Null modem cable(Also can program through USB) * Pantec/Multistar Max (All)=Null * Rex1-Null * Silver bullet/ST 1000/2000-Null * Skyview RX600 - Null * Spacestar DVB500-Null * Stealth 2000 * Techsat - Null * Ultrastar 5000-Null * Viewsat VS200- NULL -------------------------------------------------------------------------------- ---------------- |
CANADA Charlatan...
Post Number: 1073 Registered: Sep-06
Posted on |
Bronze Member Username: Pulp_fiction
Post Number: 34 Registered: Nov-07
Posted on |
