New viewsat extreme bin is out
Username: Dghumman
Ontario Canada
Post Number: 141
good news guys the new viewsat extreme bin is out it is dpsw071109x. put in the new bin and enjoy. the new bin for ultra is not here
Username: Lroy
Post Number: 303
New bins for almost all coolsats are also out.
Username: Fasoy
Where can I get this dpsw071109x file?
Username: Dizasta
Post Number: 26
i see platinum too but i need to confrim those bins
they are at ftabins dot net
Username: Donnie1973
Post Number: 1726
i would be cautious of any vs bin not on the front page at total.
Username: Fasoy
Post Number: 7
damindar ghumman,
Is this bin dpsw071109x file working?
Username: Dizasta
Post Number: 27
Yep WORKED perfectly well the FTA Bins
Username: Dghumman
Ontario Canada
Post Number: 142
danten this bin is on the total too, and it is working
Post Number: 1727
normally it is on the front page. I read where someone still had no PPV with it. I will try it. Thanks
Username: Dizasta
Post Number: 28
i have all now including ZEE Sports.
Username: Dazealex
Hi guys, a newbie here. So pardon the dumb question. But where or how do you download the bin? What is "total?"
Username: Dizasta
Post Number: 29
they are at ftabins.net and totalfta.com
Username: Hi09
Post Number: 17
hey just to confirm i went to ftabins.net
i have a viewsat extreme
is this the file i need?
DBPSW-071109X.zip
what are sat files?
thanks
Username: Frobi
Guelph, Ontario Canada
Post Number: 76
Thats a good file, Adam., same as DPSW
Username: Bestguess
A bin not at total and up loaded by someone with a "0" rating is scary to say the least!
Username: Dghumman
Ontario Canada
Post Number: 144
this bin is at total and this bin is working and i have tested it and all my channels are working now
Username: Bestguess
Thanks, works well!
Username: Bill038
Post Number: 168
I got the file for ultra at ftabins and it works. There was a spoof there, but they took it down.
Username: Zunna
Post Number: 151
wat about Pansat when will the fix come out?
