Latest Bins - All Pansats
Username: Asharfi
Post Number: 1002
Hi, friends!
I'm posting direct-links to the latest bins for Pansat receivers. If you're looking for the latest bin for your Pansat, please check in here. Pansat 2500 and 2300 are DEAD, and that's why there are no latest bins for those receivers.
Pansat 2700A:
http://203.169.142.74/~future/shine/X-87BL_071023_B75_218_api_1.zip
Pansat 2800A:
http://203.169.142.74/~future/shine/X-88BL_071023_428eubx_api_1.zip
Pansat 3500SD:
http://203.169.142.74/~future/shine/X-05BL_071023_333_api_NOCARD.zip
Pansat 250SM:
http://203.169.142.74/~future/shine/X_250BL_071023_V542A.zip
Pansat 5000:
http://203.169.142.74/~future/shine/X-95BL_071024_3130_api.zip
Pansat 6000HXC:
http://203.169.142.74/~future/shine/X-6095BL_071024_3160_E.zip
Pansat 9000HD:
http://203.169.142.74/~future/shine/HD-9000BL_071024_9022_api.zip
Pansat 9200HD:
http://203.169.142.74/~future/shine/HD-9200BL_071024_9209_api.zip
Username: Skz720
Post Number: 24
Man..i need a loader..gimme the download for the loader for Pansat 2700A
Username: Vick0901
Post Number: 18
Is that 2700a file clone safe? I just flashed my clone receiver back to 2500 and now I'm gonna flash it back to 2700. The reason I did that was, I've been flashing the latest 2700 bin's, but I couldn't get it to work. What happened was I flashed a vortex file (VorteX_87VX_071023_B75_2018...23 October.zip) which I found at ftaprosupport.c*m. I then turned on my receiver I hit ok on "installation" cuz you gotta set everything up again, went to antenna setup and selected echo7 and echo3 which is what I have. Now, when I tried to set echo7, where it says Diseqc you have numbers 0,1,2,3 well echo7 is 3, but the bar (which is supposed to increase when you find the right dish) was stuck on 30% and wouldn't increase. So, I want to know anyone with a clone 2700, are you watching dish network programming w/o channels missing to scrambled? Which bin should I use or should I wait a few days? Also, when I flashed that vortex bin, my remote was acting strange. Page down button didnt work nor the "0". I went to factory restore and tried to enter 0000, but nothing.
Username: Asharfi
Post Number: 1003
None of the above files are CLONE SAFE!
KZ,
Please visit www.ftabins.net and look for Blacklist uploader inside the Pansat section.
Username: Pops29
Hi anyone has the new Tivo bin for 2700....
Tks
Username: Asharfi
Post Number: 1044
The bin for Pansat 2700 CLONES is out, but it's only for testers ... if you want to use it, please let me know and i'll give u the link ... it's a USE AT YOUR OWN RISK bin.
Username: Timscarlet
Usa
Post Number: 258
when converting the 2500 to the 2700, you can only use the jvvh files for the 2700 conversion.
ONLY use these files with these letters in it, after conversion. no other clone files will work, especially the original 2700 files that come out. only jvvh files!
Username: Satgrl
Post Number: 204
AV any word on the jvvh files what did u find out is there a new one out...when will it come did is that jvvh guy still in this planet?
Username: Lotusbawa
I converted my Megasat YT6688 to Pansat 2700 clone exactly how it said. All that i see is a blank screen and nothing else. Can you let me know what would have gone wrong. Greatly appreciate for any help provided. I get only three satellites to select and scan. Have i used any wrong files.
READ your Channel list with Channel MAster and leave open in
background.
1. Open/Run the Blacklist updater included
2. Make sure BIN is Selected not BOOT you are writing a Bin
3. Click select BIN
4. Choose j27_205_1.bin
5. Reboot reciever, on first light/dash, Click write bin. let it write
When it is done, Be PATIENT!!!! let it reboot after 2-3 minutes you
will see B-75 Flash on display of reciever.
6. Click select BIN
7. Choose jvvh_208_1.bin
8. Reboot reciever on first light Click write bin. let it write. let
it reboot after 1 minute you will see B-75 Flash on display of
reciever.
9. now Rewrite your Channel list back, BUT, BIG BUT, you must now
select the 2700 settings in Channel master.
10. reconnect to Tv, select default key from parental options(key
menu) let it roll
11. wait for next round
Username: Lotusbawa
Hi Guys,
I did factory reset and everything is working fine. Thanks
Username: Charjam
Post Number: 224
Hey fellas i downloaded the 2700 file 218 from here and tried to load it but as soon as i hit write file it comes up errow check 2700 file any one else having this problem do i have to do a factory reset before i load it i never did before Thanks
Username: Yasir_a28
Hey Av can i have that clone save file i ll use it on my own risk thanx for 2700
Username: Rtap
FL
Post Number: 762
david have your stb off on the rear switch.hit download then quickly turn on switch on the rear.if not hit download when you see the first dash on the lcd disply.
good luck
Username: Perycles2005
Post Number: 38
AV if you could send me the Bin for Clone 2500 coverted to 2700 (jvvh218) I sure appreciate it...thanks and have a nice day
Username: Shawn0101
i up the bin in 2700 bin is 218 but mine pansat is flashing not working seem like it what should i do
Username: Satgrl
Post Number: 223
RTAP AV LK any word on jvvh bin is it gonna take 2 months again..LK did u tlk to jvvh yet? please let us all noe thnxs we appreciate it
Username: Satgrl
Post Number: 242
LK quick question sorry to bother u....have u talked to any of the coders? jvvh do u noe when he will make the conversion file thnxs appreciate ur help..
Username: Rtap
FL
Post Number: 773
satgrl i saw him having breakfast with jwh and charlie this morning at dennys.lmao
Username: Dishlover
Toronto, Ontario Canad
Post Number: 50
I ma also looking converted file 218 please
Username: Satgrl
Post Number: 243
i wish we had it so we can give to u sorry..we are still waiting
Username: Gupulamba
Brampton, Ontario Canada
Post Number: 8
i have pansat 2700A can u please tell me wah to do ????
Username: Buz
Mississauga, ON Canada
Ok, I need help. I have a Pansat 3500SD and I'm having trouble with the BIN File thing. I downloaded the file given above, but as the "Guide" says, you have to "Restore Data" by going to SD Memory in the main menu. I try to do that but whenever I press "OK" with the bin file selected, nothing happens. It's supposed to restore and reboot the receiver, but it doesn't.
Any help with this?
Thanks,
~Buz.
Username: Rtap
FL
Post Number: 798
did you unzip the bin file.
Username: Buz
Post Number: 7
Yes sir. Unzipped, put it right in there in the "CH Data" Folder. So dunno what the problem is.
Oh, and by the way, some english channels are working, excluding PPV, if that helps you at all. So I know I'm doing at least something right :D
Username: Koko_wawa
Post Number: 31
Tamara, go to dssrookie.com, free register, go to pansat section in the forum, then to pansat 2500 files you will find bin jvvh218_pt. It works great for converted 2500-2700. good luck
Username: Ak2011
So Pansat 2500a is dead rit? Any way to bring it back to life??
Username: Zia
Post Number: 12
hi liala
