Ariza 700
Username: Mike1981
Toronto, Ontario Canada
Post Number: 18
I recently DL a bin file for Ariza 700 295e dated April 14/07. It last 3 days b4 going down. ANyone know where i can find the latest bin?
ANy help would be greatly appreciated.
THanks,
Mike
Username: Ustaad_hc
Post Number: 212
new bin not out yet. so wait.
Username: Alime1386
Ghazni, Ghazni Afgha... Afghanistan
Hi mike rodrigues
1_you should download a new autorol.
2-or you can get a new keys every day, it always and every time chanage.
If you download the new autorol you are comfortable.
you donot need to chanage the key.
thank you have a good time
Username: Lklives
Post Number: 10820
there IS NO new autoroll ...use the old bin and manually input keys and shut off the autoroll
www.totalfta.com will have the latest Ariza bins/files...check it out yourself
