How to get set up on Pansat 3500SD
Username: 428217
Martinsville, Virginia USA
Here's what I do is tune on the receiver put the lauguage in it then I get up to the 3KU Band & try to look at the signal & it comes up to 36-39% range only & the other thing is the level underneath that is showing me zero %. I can not pick up any of the signals when ever I try to scan it. I am trying to get set up on American Channels as well as Indian Channels. I think it's been set at 61.5, 110, 119 & another satelite So if anyone can help me I sure would appriciate this
Thank you,
Username: Lklives
Post Number: 9541
aim the dish correctly...
