Enhanced Definition TV
Username: Header108
Post Number: 40
Well a Captiveworks600s work hooked up to a Enhanced Definition TV,if so well the picture be close to true High Def and well it work for all Channels???
Also would you set it up on just the S-Video plug or the RCA Cables which would be the best???
Username: Jameslee
Post Number: 31
Yes EDTV is nothing. EDTV is not the same at all. it is a tv format like hd but it is not hd.
Enhanced Definition TV is just SDTV well packaged at a higher price. its just digital.
In the United States, the ATSC official DTV formats include SDTV, and HDTV. EDTV is considered part of the HDTV standard.
EDTV was the real marketing terms used to bind the all types of digital Consumer Electronics Association is the one behind it to promote it.
Username: Tapeman
New York City in-HD, NY
Post Number: 1110
james
I thought enhanced is 720p
In any case if it is 16:9 wide screen
Use (RGB component RCA) for video or S-video cable
Red and white for Audio
Avoid using coax or composite yellow
