Captive Works 600s Premium Clone?
Username: Mrskullz1
Brooklyn, New York
Post Number: 11
hey guys how would it be possible to tell if you have a clone? on the cw website it says if the last 4 digits of the box are numbers then its a clone.
Well this is a c/p from their site...If your receiver serial number starts with CWP0611XXXX where XXXX is a four digit number, your receiver is not an authentic CaptiveWorks product and does not carry warranty.
Now the question is...my receiver says CWP060404741....is it a clone? It was purchased from globalwholesalers.biz
the only difference in mine is that besides it saying 00 it says 11..is does that mean its original?
also u know other ways to tell if its a clone? ive googled it but havn't gotten anything in response to this
Username: Brucester
Post Number: 414
got this off other site Guys, you are hyperventilating ... lol .... relax , CW said serial number that starts with CWP0611XXXX where XXXX is a four digit number. Does your receiver start with CWP0611XXXX ? If so, then most likely it is a clone. If it DOES NOT start with CWP0611, chances are it is legit regardless of the four digit number following. My receiver from Pansat Direct is CWP0603 followed by 4 digit numbers. My receiver is legit, working fine, never had a problem. Hope this answers your questions and calms your fears !
and this is what my number is for my cw600p cwp060304967 and it is real and you can go get more info from future-fta*info chang the*to a dot .hope this helps you
Username: Mrskullz1
Brooklyn, New York
Post Number: 15
thanks bruce
Username: Chicky56
Pembroke, ON Canada
i have a captive works cw 600s premium.my problem is this.how do i get the programs to get started.in the manuel it doesn't really tell you anything.how should i get started
Username: Brucester
Post Number: 416
*Start HERE, New Cap.Works Premium Owners*
For people just getting a CaptiveWorks Premium receiver, it may be confusing what bins to load, and what proceedures to follow. My friend just got one, and I told him to read the forums here at Future. He complained to me it was hard to figure out what files to load and in what order. I checked myself, and I can see how someone could get confused. Hope this helps.
Note - This information was originally covered in this post by LedHead, http://www.future-fta.info/Forums/sh...34&postcount=8, however the information has been updated here (ie: new files, loader, etc.)
1. Get the current 1.06 loader here:
http://www.future-fta.info/Forums/sh...ad.php?t=37252
2. Download the latest bin from here (top bin; highest bin number):
http://www.future-fta.info/Forums/fo...play.php?f=207
3. Load the latest bin (from above) with the current loader (from above) as per these instructions:
Open 1.06 loader, select the latest bin in the "File" bar across the top.
For Options, select Download S/W.
For Select a port, choose your COM port (usually 1).
Prepare reciever:
Turn off and attach the null-modem cable between the receiver and the computer serial port.
Turn back on.
With the CaptiveWorks Premium receiver on, press the front power button and hold it.
While holding it, turn off rear toggle switch, then turn on again while STILL holding front power button.
You will see "boot" on the front display.
At this point, remove your finger from the front power button and press "start" on the 1.06 loader.
Wait for the receiver to display "-end".
At this point, turn reciever off at rear switch, and then turn on again.
4. Perform Factory Default:
Using Remote, press:
Menu, Installation, Factory Default, All, ok, yes, ok.
5. Load the ICON bin found here:
http://www.future-fta.info/Forums/sh...ad.php?t=23504
(ignore the 1.13 bin found with it)
6. Load the NEW Long Channel Name Bin found here:
http://www.future-fta.info/Forums/sh...ad.php?t=41590
7. Factory Default, and then setup the receiver:
Select language
Select GMT time (-5.00 is Eastern), summer off in winter.
Search channel
Set DiSEqC switch ports and scan.
Upon completion, press F1 key (you will notice an "h" on the front panel display), and "000" to enable the patch. (repeat with "555" to enable cardshare).
Allow time for keys to roll.
Setup up OSD options:
Menu
System Settings
System
Channel NO. - SID
Key Update Message - Off
B**andD**hnet Full Name - ON
Menu
System Settings
OSD
Display Icon - YES
Auto Exit Channel List - YES
EPG Style - NEW (recommended)
Channel List - CH 10 (appears when you press OK button, lists 10 channels, or 24)
8. *Optional* Loading a custom picture/Jpeg
You can load a jpeg picture (up to 64K in size) the same way you load a bin, in boot mode.
Then you reset the receiver and activate the custome background like this:
Menu
System Settings
OSD
Background - User Logo
For tips on how to use the Universal Remote:
http://www.future-fta.info/Forums/sh...ad.php?t=22062
For a guide to the menu and features of this receiver:
http://www.future-fta.info/Forums/sh...ad.php?t=22238
For information on cloneing one CW premium to another CW premium:
http://www.future-fta.info/Forums/sh...ad.php?t=40425
For general loading/scanning info:
http://www.future-fta.info/Forums/sh...ad.php?t=37455
All other CW Premium Stickies can be found here:
http://www.future-fta.info/Forums/fo...play.php?f=206
This info helped out my buddy, and I hope it helps you to. Thanks to Ledhead, Arboristman, Tumpy, and SlckDck1 for their contributions.
Username: Brucester
Post Number: 417
and found this at the same site all the info for cw this is nice to have CaptiveWorks 600S Premium Features Guide
thanks to my buddy mrokarvi.with tp updated info by arbor.
Created by Mrokarvi
Here is a How Tos guide for all of the features available in CW600s Premium.
1.How to change EPG style? (Available in V1.13 Premium)
Now EPG style can be changed to new or old style. New EPG style looks great but if you are using full channel name Old EPG style will work good for you because it got more room to show full channel names. Here is how you can change EPG style.
Main Menu ->System settings-> OSD -> EPG Style -> Old or New
2.How to Turn ON/OFF Display Icon feature? (Available in V1.13 Premium)
Premium model allows you to see Icon in EPG and also on right upper corner of the screen. To make this feature work you have to load the Icon.BIN file to your receiver. After you have loaded the Icon.BIN file must turn this feature ON/OFF to see Icons in EPG and on screen.
Main Menu ->System settings-> OSD -> Display Icon -> Yes / NO
3.How to set 10/24 channels display?
Main Menu -> System Setting -> OSD -> Scroll down to Channel List change that option to 10 or 24.
Now whenever you will press Ok button on your remote it will show 10 channels or 24 channels.
If you press F1 key system will sort all of the channels
4.How to set Event Timer on fly?
With new OSD you can set event timer to certain event that will start in future sometimes on fly. Before set an event timer just make sure EPG is fully loaded.
EPG -> Scroll to the event that you want to tune automatically and press "Green" key from your remote. A window will open to confirm date and time that event will start; Now just Press Ok to set.
5.How to Factory Default a CW600?
New OSD the location for this feature is changed but it works exactly the same as in old OSD.
Main Menu -> Installation -> Factory Default
6.How to set time?
Main Menu -> Channels Manager -> Timer -> Time setup
7.How to Enable Patch or Disable Patch?
Exit all menus, Press F1 key; the LED will display 'H', then press '000'
8.How to Edit Patch key?
After Enable patch key, go to
Main Menu-->Accessories--> Key Menu
9.How to configure the SID sort?
From main menu->system setting->system->channel No. style can change:
Normal: Normal sort order
SID sort: Dish order
10.How to Category Search?
1) Make sure the EPG is loaded- to do that just open the EPG screen and see if the boxes are full, if not go choose any box that has no EPG and wait 15-20 sec and it will be filled. (You only need to do this once in the beginning).
2) Then exit and hit F2 on your remote.
3) Category box will open, just choose what category you want to watch and hit ok
4) After 2-3 seconds, a list of channels will open which are CURRENTLY playing these categories (every half hour this list changes when a new show is finished or started)
5) Next to the channel there is the title of the show, if you hit INFO button it will open the full information, hit INFO again and it will disappear. Just select what you like and watch.
11.How to Blind scan?
BLIND SCAN function can be accessed by going to
Main Menu-> Installation -> Antenna Setting -> selecting the satellite
that you want blind scan and press Yellow key on your remote.
12.How to Clone CW600s Box to Box?
From DigitalPlus:
1) Connect the master and slave box with twist RS232 null modem cable (pin2 to pin3, pin3 to pin2, pin5 to pin5).
2) Start the master receiver and press "POWER" key to make it standby "- - : - -".
3) Start the slave receiver, in the master box the led will display 'H' and blink it.
4) Input the password:
111 ---- Transfer S/W
222 ---- Transfer data
333 ---- Transfer data, then S/W
444 ---- Copy whole flash except Boot Loader.
5) After finishing inputting the password. Transfer will begin. When it finish, the LED will Display "-End". Disconnect the cable, start your receiver.
Note: By the different password, you can do what ever you want to do for Box to Box.
13.How to set DishPro LNBs?
DishPro LNB settings can be accessed by going to
Main Menu-> Installation-> Antenna Setting-> LNB type-> OCS-DP
14.How to Set Legacy SW21/42/44/ Switch?
Legacy Switches settings can be accessed by going to
Main Manu-> Installation-> Antenna Settings-> Legacy SW
Set the type of switch you got on your dish setup. Don't forget to set DISCQ setting to none otherwise it will not work properly.
15.How to set channel lock on certain channels?
Channels can be locked by going to
Main Manu->Channels Manager->TV Channels -> Right Arrow-> Lock/unlock go to specific channel and press OK key on your remote.
16.How to video adjustments option menu?
Video options can be accessed by pressing zero "0" when view your normal TV. Brightness, Contrast, Saturation, Hue, Sharpness and Tint can be adjusted
17.How to Auto TP?
Auto Transponder Update can be Turn ON and Turn OFF by going to:
Main Menu ->System settings-> system-> Auto TP changed to ON or OFF.
18.How to get Seven Days of EPG on a CW600s Premium?
CW600s Premium allows to get 7 days of EPG . To get full 7 days of EPG tune to any channels on listed Transponders. EPG will Populate for full 7 days in about 10-15 mins, if you have more than one echo sats connected it will take 15-30 mins to populate for all of sats.
(please keep updated mods)
Dishnetwork:
TP 18-12472
BellVU:
TP 4-12268
19.How to change Time setting from Military to Regular?
To change time from Military to Regular go to
Main Menu -> System Setting -> OSD -> Time Display Format change to 12/24.
20.How to search Favorite show channel number and time?
Shows can be searched with start time and channel number by pressing the Click on
Find key on your remote -> select OK -> then type your show name and search.
21.How to Turn ON/OFF Auto Roll feature?
Autoroll feature can be turn OFF and ON by going to:
Main Menu -> System Setting -> OSD -> Autoroll -> ON/OFF
22.How to Turn ON/OFF key update message?
Key update message can be turn OFF or ON. This feature can be accessed by going to:
Main Menu -> System Setting -> System -> Key Update Message -> ON/OFF
23.How to turn ON/OFF Dishnet/BellXvu full name display?
This unique feature can be accessed by going to:
Main Menu -> System Setting -> System -> Scroll down to the next page -> ON/OFF
24.How to select packages for Dish and Bell?
Echostar and Bell ExpressVu packages can be accessed by pressing the "SAT" Button from your remote and choose the option you like
25.How to fix NTSC/PAL scrolling screen?
This is very frustrating when we hook up our receiver to the TV and video is rolling. If we don't know how to fix it, it is imposible to fix this kind of problem some times. It happens most of the time by changing the system info by mistake or by load a custom channels list. Here is a little "how to" guide to fix this kind of problem. You can use this guide for both Premium and regular CW600s model.
Reboot your system once; just to make sure you are out of all menus
A: Press Menu
B: 3 Times down Key
C: Ok
D: OK again
E: 5 Times Down key
F: Right/Left key untill it goes to NTSC
__________________
and this event timer on the fly
bin 139 added feature-add timer in search show (GREEN_KEY)
event timer on the fly.
now you can add an event timer on the fly right in the epg.
(or many event timers)
1.load the epg.
2.press epg>scroll to find an event playing ahead
of time>press green button>pop up box with options
now is displayed with channel,date,start,stop,these
are set already by the epg,your options are repeat
1x,day,1 week,1-5,5-7,select one you like,press
"ok" on remote,now event timer is set,and is
highlighted in the epg,now you simply go to any
channel and watch tv,when your event starts the stb
will automatically change to the channel you set
event for,this is great for finding a movie or
any event you know is coming on latter that you
don't want to forget about and miss wile your
watching something else as a time filler.
to delete event timer on the fly in epg,scroll to
selected highlighted event in the epg,press "ok" on
remote,scroll to date,and press left once,press
"ok" on remote.
or you can delete it the old way,menu>channel
manager>timer>event timer>select the event>delete.
and of course,this is the old way of adding an event timer also.
Username: Chicky56
Pembroke, ON Canada
rigth now there down because of the earthquate....is there anywhere else i can get the info
Username: Chicky56
Pembroke, ON Canada
ok i got in .will tell you if everything goes well thank you
Username: Brucester
Post Number: 418
it is working on the front of page you will see enter click on it it will let you in must regester for free and you can get the new files from this site to fta-dssrookie*com chang the *to a dot .
Username: Brucester
Post Number: 419
it is eazy you will find all info and files on the site have a good night testing your new box and let me know if it works out for you thanks
Username: Hawaiian_time
Kanaka freak...
Post Number: 983
Thanks for all the info bruce. I'm waiting for my CW Premium from pansatdirect to arrive. Heard so much about this receiver I had to get one too.
Username: Brucester
Post Number: 420
all this info i get from other sites im glad to bring to this site and hawaiian_time i think you will like this box great picture great support i would like to no what you think of this box after you get it thanks have a good night
Username: Chicky56
Pembroke, ON Canada
after i went thru the factory default it tells me to PLEASE INPUT NAME? what name am i suppose to put down
Username: Edenman
Post Number: 341
I have seen fake SN stickers, cant rely on that, anymore.
Kanaka freak...
Post Number: 984
For now gotta go with trusted sites to buy from.
Username: Brucester
Post Number: 421
leonce if you did factory default go in menu go to installation factory default then all you will see a blue windo open it will ask you if you want to save curent data hit no then go to yes with the remote vol right or left but put it to yes now you will see setup wizard go english and english again and go to GMT-5:00 then search channel a new windo will open satellete name hit ok you will see list of sats pick one you got your dish at and scan it i go to number 41 it is bev nimiq1 91w then i do blind scan this will take about five min or so after all that is done hiy exit on remote or you can do fast scan by hiting red buton on remote but for first time go the long way after you exit hit f1 on remote and 000 this will enable patch let roll this will work for you make sure you enable patch or you will not get picture let me no if it works for you thanks sorry it took so long to get back to you but the game was on last night have a nice day
Username: Chicky56
ON Canada
i've tried .rigth now it says {no shannel} patch enable...how long should it take..
Username: Chicky56
ON Canada
on my screen it says scrambled channel and below it says patch enable
Username: Chicky56
ON Canada
Post Number: 7
how can i descramble the channels.did i miss something in the process
Username: Brucester
Post Number: 422
what bin are you using the latest bin for cw600p is bin139 if it is cw600s the bin is 133 or you can go on the remote and hit page down you will see keys im on bev 91 my keys are 62365BD40C8C5487470982D5DB15D12E if you are trying to get dish net the keys are 00: B846822D29B625878CB1631524650D8A 01: B388CD6095962C11C0B115D078659A10 not sure which set are working for dish it might be 00 keys if not put in 01 but for bev it is 00 keys are the good ones have fun but new bin is rolling good on my box with the bin 139
Username: Chicky56
ON Canada
Post Number: 8
my receiver is cw-600S premium.i used 1.13 bin.did i install the wrong one.if yes can i reinstall the new one..where can i find 133 bin.. do i change the case ID,IDENT,INDEX do i leave these alone
Username: Brucester
Post Number: 423
you do not put bin 133 it is bin 139 for cw600p
Username: Brucester
Post Number: 425
Username: Chicky56
ON Canada
Post Number: 9
is this the one CW600PV1.39_Recorder_06032007.zip if not i can't find it
Username: Brucester
Post Number: 426
bingo you got it did you get loader and null 232 cable
Username: Brucester
Post Number: 427
in using the 106 loader and make sure to unzip the file to a bin
Username: Chicky56
ON Canada
Post Number: 10
unzipped. what do you mean by null 232 cable
Username: Chicky56
ON Canada
Post Number: 11
downloading files
Username: Chicky56
ON Canada
Post Number: 12
got picture no volume
Username: Chicky56
ON Canada
Post Number: 13
FINALLY WORKING I want to thank you very much for the help you gave me..thanks a lot P.S. looks good
Username: Brucester
Post Number: 428
glad to help you sorry it took so long hope you enjoy your new box have a good night ps: if you need to know any thing else just ask ill try to help if i can. by the way what sat are you aimed at im at 91w which is bev i get around 400 channels
Username: Chicky56
ON Canada
Post Number: 14
same here..one more question hopfully tonight..I lost most of my channels and i can't seem to download more then twelve.doing something wrong again.I'm completely new to this so bare with me thanks
Username: Brucester
Post Number: 429
just go to menu installation antenna setting do scan auto red button first put your sat name at the top mine is like this 41.nimiq 1 (91)than hit the red button you will see the channels listing let me no if this works for you ps: if you did a factory reset you have to enable patch again f1 000 let me know how you make out
Username: Chicky56
ON Canada
Post Number: 15
quitting for the night..contact you tomorow on progress ..thanks again
Username: Chicky56
ON Canada
Post Number: 16
I'm back..problems all my channels say weak signal,no EPG or channel scrambled..help
Username: Brucester
Post Number: 433
what is the strength quality on the sat you are trying to scan mine is at strength on my box 73 quality is 88
Username: Chicky56
ON Canada
Post Number: 18
st 87 qua 76
Username: Brucester
Post Number: 434
if all is good with the quality and strength you might want to do factory reset you will find it in menu on the remote hit menu installation you will see factory reset go to it hit ok on remote it will ask you if you want to save no hit ok you will see it say do you want to delete all with the volume button move it to yes it will delete all now you will see blue screen go to english and english again CMT-5:00 hit ok pick you sat you want to scan once you did this hit red button on the bottom of the remote when it is done scanning hit exit 3 times on remote and if you are using bin 139 the box will roll after you hit f1 000 on the remote and if this does not work you will have to check your dish it did snow in ottawa ont last night and got windy might have to tweek your dish to get better signal let me no if this works for you
Username: Brucester
Post Number: 435
be sure that the patch is inable if it is in disableyou will get no picture or sound on the remote you will see right above the red button f1 hit it you will see h on your box hit 000 a box will open telling you if it is inable or disable it must be in inable
Username: Chicky56
ON Canada
Post Number: 19
still no epg. weak signal. channel scrambled,still get a hundred channels that i can watch but thats it..talk on phone maybe
Username: Brucester
Post Number: 436
are you from around ottawa ont if not call me left my number in the privite message i sent you
Username: Georgeranger82
Texas Usa
you seem to be very knowledgable about the captive works 600 s premium. is all the info you have listed on this thread apply the same for the cw 600 s ?? i just got one off of ebay and should be recieving it soon, any and all help would be great im really interested in ppv type of programs had some questions about firm ware soft ware kind of stuff
Username: Brucester
Post Number: 457
this is the info for the cw600s *Start HERE, New Cap.Works REGULAR Owner*
The following does not apply to the Captive Works Premium reciever.
The new CaptiveWorks 600s REGULAR reciever comes loaded from the factory with the Kround OSD. If you just got a new one, these are the instructions.
(If it is old, you may have to reffer to these instructions, and ask someone in the forums for some help:http://www.future-fta.info/Forums/sh...d.php?t=20290)
1. Get the current 1.05 loader here:
http://www.future-fta.info/Forums/sh...ad.php?t=20296
http://www.future-fta.info/Forums/fo...play.php?f=176
Open 1.05 loader, select the latest bin in the "File" bar across the top.
Prepare reciever:
Turn off and attach the null-modem cable between the reciever and the computer serial port.
Turn back on.
With the CaptiveWorks 600s REGULAR reciever on, press the front power button and hold it.
At this point, remove your finger from the front power button and press "start" on the 1.05 loader.
Wait for the reciever to display "-end".
5. Setup the reciever:
Select language
Search channel
Menu
System Settings
System
Channel NO. - SID
Menu
System Settings
OSD
Now, you don't have to select these options, but I do recommend them.
Thanks to the other Mods who contributed to this thread. For more info regarding the Captive Works 600s Regular/Normal (not premium) reciever, visit our stickies:
http://203.169.142.72/~future/Forums...play.php?f=172
GINYODA -
__________________
Username: Chicky56
ON Canada
Post Number: 20
bruce...same problem..channels scrambled since last night..still scrambled..tried everything,is there a new autoroll out there if there is can i get it..
Username: Brucester
Post Number: 461
new bin out on sunday morning it is bin 140 04082007 this bin is working good you can get it at future-fta*info change the * to a dot .if you cant get it going give me a call but if you put in new bin all will work good for you just put in bin leave it roll with in five mins you will have tv again
Username: Chicky56
ON Canada
Post Number: 21
finally working..hope this work for a while...thanks bruce..talk to you later
Username: Brucester
Post Number: 462
any time chick the last bin worked good for over a month 139 but on saturday night before the ufc came on bev rolled the keys sending out no good keys to the box but the 140 bin fixed all that have a nice day chick
Username: Gmirza
hey guys i need help big time i guess i have messed up my keys by deleting an important first line of my keys which i shouldnt have touched please kindy send photo snap shot to punch keys for Dish Network for ViewSat VS 2000 Platinum
Username: Brucester
Post Number: 463
go start your own thread this is for cw not viewsat you will get better help this is hijacking some one thread go out and start a new thread you will get better help have a nice day
