Bronze Member Username: Reza6652Post Number: 11 Registered: Jan-07 | I want to get this SlingBox, which lets you watch your tv from anywhere on the internet... Just wanted to know if it works with FTA, i can use either a CW 600 Premium or a VS Ultra. the website is www.slingbox.com Any help is appreciated. Thanks |
Silver Member Username: Cartier1Post Number: 271 Registered: Feb-07 | i dont know about fta . but i did it with cable. and it will cost you more than you think. you will have to leave your cable box on all the time. so think about that if the fta reciever works with sling then you may risque of overheating your box. |
