Help with stuck receiver.
Username: Roundtree
Post Number: 19
My receiver is stuck on "ON" display and will not take a bin. Should I through it out and get another one, or is there a way I can still revive it. Is there a reset button inside.
I was changing channels and it blacked out. I waited a few secs then power off/on and now it is stuck on "ON" display.
Pansat 2500A clone (Dr sat version.)
Username: Destine0429
Quebec Canada
Post Number: 101
Did you try to shut it off by the back of the box?
Username: Roundtree
Post Number: 20
Yes I power off/on the back. Remote buttons are not working not even power.
Username: Bones714
Saigon, sO.C...
Post Number: 240
try unpluggin it from the power outlet
Quebec Canada
Post Number: 104
Wow, ummmm... When was it last working? What did you do just before it stopped working?
Username: Roundtree
Post Number: 21
unplugged it and left it off for about an hour and it still did not work. Then I posted my original question.
Username: Roundtree
Post Number: 22
Julie,
I was just changing channels and It gave a blank black screen. I power cycled and now nothing.
Quebec Canada
Post Number: 106
Gez, normally I would ask my hubby what to do, but he's away for the weekend. If no one comes up with a solution tonight, I will find out tomorrow. Good Luck
Quebec Canada
Post Number: 114
Ok, I spoke with my hubby and he said for you to try this.
Download Factory Flash into the box. I think it's 222 or 224. DOn't know if the factory flash changes with different boxes. This you will need to find out. Make sure you download it twice. The wait until it says "Complete". After this, redownload the bin you were trying. Let me know. Good Luck
