Viewsat extreme not working
Username: Coolgoose
Post Number: 8
I have a viewsat extreme and its been running on the latest bin for two days. My tv is blank today and all it shows is "on" in the display of the receiver. Should I load the bin again??
Username: Ke5aqn
Shawnee, OK USA
Post Number: 466
make sure you have all setting correct, coax connected and so on
after that make sure your key's are correct.
then let us know
Username: Coolgoose
Post Number: 9
The tv is completely blank and the remote doesnt work. All it shows on the display is "on" where it used to show 00:00. Cannot see anything on tv so cant change keys
Username: Ke5aqn
Shawnee, OK USA
Post Number: 467
did you reboot it?
turn off the switch on the back wait a min or so then turn it back on....post the results
Username: Coolgoose
Post Number: 10
I tried that but the result is the same.
Username: Mc_sunny
Post Number: 991
Load The Virgen File..2051 bin And Then Load The Lates Bin for ur vs
Username: Ke5aqn
Shawnee, OK USA
Post Number: 469
ok you will need to jtag it and start all over no big deal.
Go HERE the home Viewsat forum. Their you will find a section just for that receiver and instructions on how to do that.
Username: Coolgoose
Post Number: 11
I tried loading the bin again and the result is the same.it just shows "on".This bin was working for two days.
Username: Mc_sunny
Post Number: 992
First load the factory bin..which is XTREME_v2051_factory_bin.
Then load the latest bin Xtreme DBPSW-070117X
Username: Ke5aqn
Shawnee, OK USA
Post Number: 473
I would also go the home forum and download the .bin again
you may have a bad file
Username: Coolgoose
Post Number: 12
Can I load this factory bin (VS2000_NEWOSD_XTREME_v2061_factory_bin)
from totalfta , I didnt find v2051. Or is there a latest factory bin which i can load
Username: Coolgoose
Post Number: 13
I loaded the factory bin (VS2000_NEWOSD_XTREME_v2061_factory_bin) and then loaded DBPSW-070117X.
Now it says "noCH". What should I do now. please help
Username: Grimreeper
Post Number: 284
Do a channel scan let the keys roll and watch tv
Username: Mc_sunny
Post Number: 993
set up antenna setting....do F1 scan...wait for keys to roll and watch tv
Username: Prfrmnj
Post Number: 1582
Mc - Not trying to contridict you, but wouldn't "F2" update the TP's. I've found that when loading/flashing the preset TP's are not always complete. But I'm not sure if it's just me, so let me know what you think... Peace!
Username: Coolgoose
Post Number: 14
Thanks everyone , I didnt know noCH means no channel. Once again I thank everyone who helped me in this thread
Username: Ke5aqn
Shawnee, OK USA
Post Number: 515
glad we could help cool goose!
