Can the fta mess up a sub?
Username: Donnie1973
Post Number: 27
Hello, Ive got a 2700a, last night was setting one up and now my sub in another room isnt getting all my channels. Some 110 and 119 are showing bad signal. Some are working off of both sats though. Any ideas?? My fta is working fine...
dish pro lnb, no diseqc switch. I also noticed with new bin file the legacy switch option in the antanna set up. Guess thats for legacy users only? Thanks.
Username: Lklives
Post Number: 3468
U cannot use legacy SW switch with Pansat receivers!...
Use DP 34 switch and U will be fine...your problem is a switch issue
Post Number: 30
no no, im not using legacy. just the dp lnb. its been connected for weeks, both sub and 2700a were fine till last night. fta is still fine, just the sub is acting crazy. Reset it a couple times. not sure if it was something i did. (sure it was) the only thing i did any different was looking through the legacy sw options in the antanna setup.
Username: Lklives
Post Number: 3470
Then reset the Pansat back to Dish Pro 11250 in settings and do a reboot...also try rebooting the DN receiver, unplug for 1-2 minutes..
Post Number: 32
Yeah did that... maybe my reciever went bad. I have another dn sub I can try. Shoulda tried that second anyway. Thanks LK. How long after getting in to this stuff did your hair turn grey and fall out?? A lot to learn on these things for sure.
Username: Outlooker202
Post Number: 12
just use 2x4 or 3x4 swtich
________nx4
SAT--->Switch ----> (DN switch) ---> SUB DN reci
_________I
_________I
_________I
_________4x1 Disqc ---->FTA box
It works all the time
Username: Lklives
Post Number: 3475
My hair is NOT gray,( in fact NO gray) and all fallen out!...but my goatee is gray/white and sunbleached!
Username: Pep
Post Number: 15
This is my working DISHPRO LNB SET UP
I convert my regular channel thru channel master
using dispro conversion and customize it to 25600
for vertical signal.
Installation set up:
lnb - standard
freq- 11250
just try above set up if it works for ur rcvr
