Viewsat 2000 Platinum
Username: Berlin
California USA
I have 2 Viewsat 2000 Platinum, I downloaded wrong bin, Apt-get & satinfo file to the 1st receiver, and the 2nd one with the right bin works great. My question is : Can I upload from the 2nd receiver that works fine to the one that I mess up? Does anyone know how to do it? should I upload from the 1st receiver to my PC and then load it to the 2nd receiver or there is any other method to do that, plz need your expertise here.
Thanks alot
Username: Outlooker202
Post Number: 14
DAMN, you gotta read your sentence structure
(....upload from 1st to my PC.....) <----make no sense
The method you are trying to describe is CLONING
Plug in 9pin NULL CABLE in both VS
Using the good ird(reciever) turn on and watch any channel
Now turn on the dead/non working IRD it should start transfering the data (everything, CHA, SAT, CODE, OS (bin)) just press okay if the status bar stops. it waiting for approval.
Yes, you can
Username: M_onorato
I need the loader2 for the viewstat 2000 platinum
Username: Evadelparaiso
Puerto Rico
Post Number: 1057
http://www.dss***tester.com/files.php?cat=17
remove ***. Enjoy
Username: Azpride
Post Number: 7
hey EVA, which cable to connect the receiver and computer? 9 pins connector? then what?
i tried 9 pins ( F to F), execute loader2, but still sit there, nothing happens??????
help please
Username: Boyce
Post Number: 282
https://www.ecoustics.com/electronics/forum/home-video/240311.html
Username: Berlin
California USA
Post Number: 7
outlooker202 : Sorry to make you confuse with my sentence, my mistake. (What I mean ....upload from the good one to my PC then download it to the dead one... :-) )
Anyway thanks alot for your help.
