Channel master
Username: Magicstick
Houston , Texas United States
Could somone point me in the right direction for instructions on operating channel master. I have a pansat 3500s. I am really confused. i think this is allI need to get myy channels working properly. Please let me know what all is required.
Thanks
Username: The_wank_artist
Post Number: 940
Get the program; load it to your computer...
From here it depends what you want to do.
If you have downloaded a pre-made channel list then open the that file, connect computer and receiver and write it to the receiver (under tools). Very much like loading a bin.
If you are making/editing your preexisting channel list that is on your receiver currently, then connect computer/receiver, read from receiver (under tools). Once done you'll have the channel list from your receiver displayed in front of you. Edit it as you see fit, then save it and then write it to the receiver
Username: Wakenbake
Post Number: 210
charles
scan each sat
