The problem is fixed (ppv,xxx, & more ALL work )
Username: Nickusami
Macomb, MI USA
Ok Friends ,
The problem is fixed . PPV , International , HBO ,Max ,Starz & $xxx ( that's what u guys looking for ) Channels . All of these are viewable now. As far as I know the code itself wont work . You need to load the new file fix . If you can not get it from the link blow , go to ( Al7bar website but at .tk not com) register & wait 24 hours & then down load the file .
I tried this , and it works great for pansat 3500 sd and Vortex pro 3500s
For vortex 3500 you need the file :
( VorteX_05VX_061106_3502 )
For Pansat 3500 you need the file :
( X-05BL_060610_352Tivo_eubx_api_au_1 )
DO NOT use the file pansat to run vortex . It may kill your receiver .
These above are good & I tried them . This the second day works great .
For Pansat 2700 you need the file :
( X-87BL_060609_272_api_2 ) I haven't try this .
Good luck guys .
GodBless
Nick
Username: Nickusami
Macomb, MI USA
Post Number: 7
Ok Friends ,
http://forums.al7bar( dot )tk/showthread.php?t=161481&highlight=vortex
http://forums.al7bar( dot )tk/showthread.php?t=161307
the above link wont work unless you take the parenteses out & put pint instead !!
Good luck guys .
GodBless
Nick
Username: Lklives
Post Number: 3348
ECM Problems were fixed 5-6 days ago when Viewsat released all their new files..and then most all FTA makers followed within 1-2 days later..
Username: Kumudinia
Post Number: 23
Where can I find those Viewsat files? I lost most of the channels in my Viewsat Xtreame
Username: Lklives
Post Number: 3350
Any reputable DSS site has them...
dsscentral.ne*t
dsscommunity.c*om
dsstester.c*om
hashhu.c8om
future-fta.info
gat-s.biz
fta-updates.com
Username: Rufidada
Post Number: 35
hi
i am completely out of this problem for the last whole week or 2. i have megasat 4000 can any one tell me what i have to do and do i need to change the dish position . mine is echostar 148 and nagravision 2
thanks
Username: Rufa33
Post Number: 9
Damn, LK what you do for living watching DSS sites? just wondering ? Thanks anyhow for posting them here. It's true they are good sites but prefer the www.dsstester.c*om as the best site so far. Delete the * to go to the site.
Username: Alehandro
Post Number: 10
i need help with my megasat yt6688 i dont know what bin to load to fix ppv, please give me a hand !!!!
Username: Vbajic
how can i find these files for captive works receiver.
thanx
Username: Wakenbake
Post Number: 193
vlad
join @ future-fta.info (www.)
its there
Username: Lklives
Post Number: 3445
I am retired Lt Col after 30 years in the military...I have many hobbies and the time to do them all!
