Fortec X-85CS_273T_GC_DN_BEV_RTN_TVE_4sec_api(N).bin
Username: Abj
Post Number: 74
Here is the latest from BL with fix for DN and Bev autoroll>Also added the clone safe routines and Tivo Hughes ir remote code and RTN_TVE and 4 second remote delay.This bin is good for all clones,2500a, Fortec Ultras and all other clones that 272t2 bin works on.
UPDATE:
The second file is for Jkeys only. Do not try to load it with loader.It is jatag file only.
You can find the file at www.totalfta.com under fortec file section. Good Luck to all the fortec owners and clone receiver owners
Username: Lklives
Post Number: 1438
dsscommunity.c*om forums...either Fortec or Pansat files area...both have it has this also...notice the globecast is put back into the bin for U globecast viewers..
Posted: Sat Mar 18, 2006 1:28 pm Post subject: X-85CS_060318_273T_GC_DN_BEV_RTN_TVE_4sec_api(N).bin
Here is the latest release from BL with fix for DN and autoroll. Also added the Clone Safe Routines and Tivo Hughes ir remote codes and RTN_TVE and 4 second remote delay. Also changed the background to the Lightning Background. This bin is good for all clones , 2500A , Fortec Ultras and all other clones that the 272t2 bin works on. I have tested it on my Fortec Ultra with bad chipset combo 2005 70PTFN and all is good. DN Autorolling fine. Once again This fix Goes out to all involved from the begining to find all these malicious codes in the past bin. Thanks especially to YONO and JVVH for there continued support.
Username: Fuad
Louisville, Ky
Post Number: 7
i downloaded 273_gc bin and now i dont have picture.on tv is black picture and on the receiver i got the line is moving left and wright.what to do to fix the problem.thanks
Username: Cincy
Post Number: 10
My f*rtec life time ultra works great with this bin
Username: Fuad
Louisville, Ky
Post Number: 8
ok,i got the light on receiver but i can not watch nothing,i told you the tv is black
Username: Lklives
Post Number: 1565
U have night rider lights..due to improper uploading of the bin...
Here is how to recover from the "Night Rider" (flashing lights):
1. Try re-flashing the factory boot/flash bin again using the below directions. That gives you FTA ONLY. Follow the above procedure.
2. Then, when that works use the latest flash to get the scrambled channels.
3. Download a channel list and/or do a channel scan on each sat.
4. When flashing, be sure to wait not only until is says done. But you need to wait until it reboots and actually goes to a channel number.
Here are a few tips if you are having difficulty flashing:
I would advise everyone to read a set up guide before flashing. But, since people have been having some problems, I have revised this to provide more detailed information. But this is not intended to be a substitute.
1. Make sure you use the proper serial cable for your receiver:
Most Fortec and Pansat use a straight through cable with DB9 females on both ends.
The Blackbird and pansat 2700/3500 uses null (crossover) cable, which crosses over pins 2 and 3.
2, With the power turned off, connect it to your computer and receiver using the serial connector. Use serial port # 1 if you can.
3. If you do not have a working serial port, you must install one or use a computer that has one.
4. Use the appropriate loader. I like BL updater 1.4
5. Select the file. Make sure that it is the correct flash for your receiver.
6. Select the COM port your receiver is connected to. If you do not know, what it is try #1 first.
7. Enter the correct model name and number. (key:global)
8. Check off the correct function box. Your choices are boot, flash or channel list. To FLASH your receiver you would use FLASH. Most flashes do not require a separate boot; so do not load both separately.
9. Turn on the receiver power from the back switch.
10. As soon as you see the lights flash,very first light -- IMMEDIATELY press download. Timing is critical..
11. Wait until it COMPLETES and reboots.
Username: Fuad
Louisville, Ky
Post Number: 9
some body know the factory bin i got 041101_250
is that wright factory bin
Username: Lklives
Post Number: 1571
it'll work...222 or 224 are original factory bins...but 250 is OK too..
