Archive through August 18, 2005
Leman
where and how can i get a new flash or jeepers program for my atmega? any help would be graet Thanx.
LK
From the files area of any reputable DSS site,U can get flashs,jeepers or whatever files U want.
abdi
I am confused
MFA
hey, any clue on nagra 2? WHEN IF AT ALL?
ugugjhbjhb
Key0= A6 00 E2 C0 56 7E 4A 45 <---8/5
Need new keys!!! Anyone have them???
Username: Mooch_1993
The zero keypad no longer works on my dish tv remote. Is there anyway to bypass the 0000 password within the parental control menu in order to change a key?
litlle ceasar
ugugjhbjhb.................
thank you thank you!!!!
Key0: A6 00 E2 C0 56 7E 4A 45 ** Active
Key1: 88 7B D0 37 D9 BA 43 73
kookoo
Hi,does anybody know the code for saturday august 6th?If you do please inform me as soon as possible.Thank You.
where do people get these codes? I would just like to know so I don't have to ask on this forum. I know this has probably been answer before but i can't seem to find it thanks
LK
There are many FREE software files out there available at every reputable DSS site that produces the NEW keys for you directly to your computer (just be online at no specific site), every time they change..KEYMASTER is my choice,as well as Getkeys and Jeepers..dsscommunity. com has KEYMASTER in the File Share FTA area available for U to FREE download..
How do you flash a fortec star lifetime ultra?
I have the f/f "straight" serial cable plugged in from com1 into the back of the reciever. But I always get flash update fail..
my pansat is not working,the keys have not change so can you please help me to fix the problem,thanks you
LK
anon...sounds like U either have a bad cable or bad or wrong serial comport..
anon..do a reset after every key change input or any problems...BACK of receiver,power off,wait 1 minute,power on,turn to channel 300
LK, thanks for the reply.
My cable is good. I can do a loopback check using hyperterminal on COM1. I use the paperclip trick on pins 5 & 6.
Any other suggestions?
-Doug aka Anon
LK
Try com2 or another computer...and are U sure U have the straight female ends Db9 cable,not the crossover null modem cable..100% of the time this message is caused from bad/wrong cable or bad/wrong comport..also try using another STB updater..
LK
also make sure U're flashing the right bin for your receiver...
LK,
I tried both my computers. So that is not the case. And 'yes', my cable is straight.
I am using this stub:
http://www.d$$central.net/cgi-bin/schlabo4/dl.pl?Fortecstar-STB-Updater-v3.31
And a variety of bin in the same location. None seem to work.
Can I write my own bin? Has anyone ever done this?
hatonia
does anybody have new keys for dish?
aka
hey guys can someone tell me how to get plboy channals if you know plz let me know thanx.
aka
DISHNET KEYS Current
08-05-05 7:25pm EST
aka
hey guys does n e one know how i can get p l a y boy chanels plz let me know. thanx
Username: Maple_leaf
Post Number: 668
That's getting to be an old ??
bg1
is all that crap on the the xtra channel true about new electronic devices blocking the max and starz and ten spice channels true or is there a bin file for them
Coldsteel
I appreciate all the info and time people have taken here but I read these posts and they're like Greek to me ... is there anywhere I can go to have things explained in a simple manner?
I have Dish Network (811 receiver) and would like to 'test' the PPV channels without paying for them first.
If this is possible can it be done without purchasing other equipment?
Thanks in advance for your help and expertise.
Username: Jmill1948
Chester, Va Usa
Post Number: 712
aka get a subscription...........
guest123
anyone have updated keys for today Aug 9 ??
aka
08-05-05 7:25pm EST
annonmoys
new codes here are old before posted, maestra not updated either...................... aargh!!!
lovethename
anyone have the new dish keys?
08-11-05 1:35pm EST
Key1: DB 76 17 77 A1 CA 75 DC ** Active
lovethename
thank you
heart
Thank you Anonymous. God Bless You.
Cassie
Those codes aren't working for me, are there anymore?
Username: Omar786
cassie reset ur box from the back
these codes aren't working for me....anyone have newer ones?!?!?! Please!!
: DUMB and DUMBER :-)
Cassie
LMAO PHUCKEN MORONS IT'S NOT THE KEY THAT DON'T WORK IT'S YOUR PHUCKEN DUMBAZZ BRAINS !!!
ALL U NEED IS 2 ENTER THE CORRECT ONES !!
Post Number: 682
Talking to your self again i see.
mattwuzhere
i see the codes and i have the stuff where i can put the codes in i just want to know where do i put them in i cant find where they go any1 kno?
I put the codes in my Ultima and as soon as I go back the active Key is 0 and not 1. Key 1 still has the new keys.
How can I fix this problem?
I have installed autoroll. Works great, but when viewing the code it shows DA 76 17 ....etc. instead of DB 76 17 .... why?
LK
Thats common with autorolls...your picture might start freezing up though..if so,then manually correct the 1st 2 digits of that key back to DB (which are the correct keys)..
I have tried to change the first 2 digits but it does not work. I then changed them back to DA.. and it's back in business. I don't have any problem.. just curious. Thanks for the reply LK.
I have read the entire thread and others to educate myself and I seem to remember this being mentioned before but I was unable to locate where.
LocalUS
Dish just went down.. anyone have the new keys or a link to where i can find an autoroll?? Thanks
JDMB0iKT
does anyone have the new keys?..thank you
jack bower
08-12-05 5:35pm EST
Key0: D6 96 E1 CE C0 00 AD 0F ** Active
ragamuffin
New Key 0
Anyone new key plzzzzzz
bunki
I OFTEN HAVE THIS HAPPEN TO ME... I CHANGE TO THE NEW KEYS WITH NO RESULT UNTIL THE NEXT SET OF KEYS COME OUT... ANY COMMENTS?
this one is not working
Anyone new keys plzz
aka
08-12-05 5:35pm EST
aka
Fortec key change method
1)With receiver hooked up to TV and satellite:
2)Press MENU on the remote control
3)Then right side arrow to CHANNEL EDIT
4)Go down to CODE, and press OK, and enter 1010 (could also be 1668 or 1688)
5)Then right side arrow to turn OFF, KEYCODE FUNCTION
6)Go to NAGRAVISION and press OK
7)Now press the right side arrow next to the OK button 11 times until it says ((DISH NETWORK))
8)Go down to KEY Number, then right side arrow to set to "00".
9)Go down to Key Data and enter the latest KEY with your remote control.
D5 6F BB 83 00 D8 B0 4E ...(example only)
10)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "00" is saved.
11)Go up to the Key and Go to the right "1 time" (that will change key 00 to 01
12)Go Down and enter latest Key 01 change ..11 B1 AA A7 8B 9E 45 8B (example only)
13)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "01" is saved.
14)Press EXIT once.
15)Then right side arrow to turn Code back "ON" and enter "1668" then EXIT, EXIT.
16)Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset
guest 123
Need new keys for Saturday 13th Aug. please.....
Post Number: 689
Really?
Username: Markleo
keyo 11 64 6B 2E A5 26 ED 7E
ke1 40 B2 B9 7A C2 C1 53 75 active
fooodcritic
Dood those keys dont work.
i tried them both.
Peter5632
I have a Fortec Star Lifetime Ultra. The channels seem to be disappearing on Nagravision. What's the story? I heard something about the channels switching to Nagravision 2? That true? If so, how do I modify my unit?
Thank you,
Post Number: 692
Do a yahoo search for n2 fix it's there all for you.
waslowski
Does anyone have the newest keys?
Post Number: 703
Yes i do!!
DICKLESS
-No U don't Mable, U don't even have a dick.
U dickless wounder.
Post Number: 704
Puss Bag Little boy eat me idiot
wat r da new keys
Username: Markleo
new keys please
-__-
KEY0: D6 96 E1 CE C0 00 AD 0F <active>
KEY1: DB 76 17 77 A1 CA 75 DC
Enjoy! o_O
Username: Markleo
thank you is working fine
couchtator
Can someone explain "autoroll" to me. And how to set it up thx
-__-
Autoroll means that ur reciever will automatically change the keys so u don't have to enter them everytime they change.
To set it up u need to find a boot rom file(usually called a bin file for pansat) for ur reciever that contains autoroll in it and install it on to ur reciever
Thank you Maple Leaf. Will Try it
pingon
latest key please!!!!!!
whif7
could anybody who has the latest keys post them please!!!!!!!!!!!!!!!!!thanks
Username: Salvatore316
Post Number: 16
i'm trying to get them now. hold on
farmhemi
Does anyone have the newest keys? Can you please post them.
Post Number: 17
Why is this Get Keys file bin always showing the same keys even though the system went down a little while ago?
litlle ceasar
papacito has them!
look in "here's the new keys"
Username: Jlop
Dish Network: KEY 1 is Active
KEY1: 8D 11 96 22 A3 25 D7 04
_________________
pingon
can anybody help me with the new keys?
i can't find it
key
Post Number: 18
post them here please!!!!!!!!!
LK
08-15-05 7:35pm EST
Key1: 8D 11 96 22 A3 25 D7 04 ** Active
has dishnetwork cut off the ppv channels, please tell us all
i have lost my ppv too
CEO DN
IF U WANT PPV THEN GET A subscription...........subscription...........subscription...........subscriptio n...........subscription...........subscription...........subscription.......... .subscription...........subscription...........subscription...........subscripti on...........
Post Number: 714
ppv gone LOL
mr. smith 01988
new key codes please!!!
Username: Ljm
E6 96 B2 0A 37 35 20 21
Key 0
roper
anyone have the new dish keys? thanks!!!
Farmhemi
not for me LOL
dishhelpplease
nicky_kh
Hello all
I'm trying to open the scrabled channles by my pansat 2700a. I have tried downloading the .bin files available everywhere, but I face the error msge: flash update fail.
First: is this file what I need to have to be able to watch scram. channles?
Second: why am I recieveing such an error
LK
08-17-05 7:00pm EST
Key0: E6 96 B2 0A 37 35 20 21 ** Active
Dish just went out. Does anyone have the current keys? Thanks
pamlin
any new keys for dishnet
pirumosho
the new key is
key 1 c4 b1 b5 b5 dd 6e af 81
Thanks pirumosho!
aog
can i get european or mexican channels with my pansat 2500a ? how?
LK
08-18-05 1:00pm EST
Key1: C4 B1 B5 B5 DD 6E AF 81 <--Active
GREMLOCK
08-18-05 1:00pm EST
Are these keys working since dish moved to nag2? will these keys work for a cools*t 4000 pro?
