Best receiver for Definitive Procinema 60???
Username: Jlwalw
I just purchased a Definitive ProCinema 60 and now I need expert advise on which receiver to use with it that would bring out the best sound quality in the ProCinema 60. Any recommendations? The speakers will be used for mostly movies. Thanks for the help.
Username: Project6
Post Number: 1177
What is your budget?
Username: Elitefan1
Post Number: 577
For around $500 or so you can get the Marantz5400 which will be perfect for your Def tech's. The 5400 is very powerful for such a budget unit and has a nice warm sound that fits the Def Tech's. I don't think you can do any better for the money.
