DTS Neo:6
Username: Bryanbmur
I was wondering how many people use DTS Neo:6 and do you like it? What are its positives and negatives? Thanks
Username: Sandiego
Post Number: 32
I used to use it only for music, that way the 6th channel would put out a little sound along with the rest. Now I use Prologic IIx
Username: Project6
Post Number: 1774
Let's make it simple.
Positive = if the listener likes it.
Negative = if the listener does not like it.
You decide if you like it or not, after all, your ears are listening.
