Bin file 510 which was release over night still has major problems. Seems to work OK on Echo 7 but does a major Freeze on echo 8. Remote locks up and you have to use the rocker arm. Anyone else having this problems?
I took bin 510 off my STB. It is not worth loading. It freezes and you have to reboot the STB and it happens again. I'm waiting this one out. Coder will again come out with another bin.
Tooter is correct, but I got lucky and when EPG came up I cancelled it and pushed the menu button with the thumb drive already in the STB and I was able to switch bin files. I went back to 507. 510 I wouldn't recommend.
