I have two reveivers with two dish with two lnbs as well as two switches. Each switch has only one output for each receiver. So far both receivers are fine. How can I wire a third receiver to one of the dish? Do I need another switch with two receiver outputs and what switch would that be? Thanks
Yo can also do something cheap and easy Split one of the DISEqC switches using a 2000MHz splitter This will let yo share TPs on 2 of yor 3 receivers In many cases many people won't watch all 3 TVs at same time And if yo do it will let yo watch different channels on same TP on 2 of yor 3 receivers
