New member Username: Lubfr01Post Number: 9 Registered: Sep-07 | any such fix out there ? |
Bronze Member Username: BanglePost Number: 37 Registered: Jan-08 | It is out there for B-75 already ftatalk.com |
New member Username: Lubfr01Post Number: 10 Registered: Sep-07 | Mr. Le that is for original Pansat 2700 not converted ones. |
Platinum Member Username: NydasPost Number: 10793 Registered: Jun-06 | Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. http://public.box.net/2500_full_kit You must select whether you want to have the old b75 files or PUFF files. If you have b75 boot and want to use the PUFF BINs , you must convert to PUFF boot If you have PUFF boot and want to use th eb75 version, you must convert to b-75 boot Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Platinum Member Username: LklivesPost Number: 15782 Registered: Jan-06 | Yes there are a couple new "268" B75 2500-2700 converted fixes posted at dsscomunity.. also new 268 Puff 2400-2700 fixes too.. |
Platinum Member Username: NydasPost Number: 10797 Registered: Jun-06 | Do not load any conversion b75 BINs from any other source. There is only one b75 BIN available - the tronics268_b75.bin [link removed] |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2475 Registered: Jan-08 | Dont go to dsscommunity LK sold your E-Mail and IP adress |
Bronze Member Username: SherSt anne de bellevue, Quebec Canada Post Number: 17 Registered: Apr-07 | D.N & Bev down |
Platinum Member Username: NydasPost Number: 10805 Registered: Jun-06 | DN is up. There are reports of BEV being down. |
Bronze Member Username: Popol_vuhPost Number: 51 Registered: Jan-08 | Exactly my experience... (Tronics268) |
Platinum Member Username: NydasPost Number: 10814 Registered: Jun-06 | There are 4 b75, over 8 PUFF and One LZMA BIN currently available for 2500/FLU converted to 2700 work-a-like. [link removed] |
