Rom102 rev 108
Username: Jaa
Post Number: 11
i have a powersync unlocker and i am haveing trouble unlocking rom 102 rev 108 card i am new to this and i need to flash the unlocker and info greatly appreciated thanks in advance
Username: Bandizzy
Post Number: 237
Look for RM-1A it should contain the RSX1.hex flash. You'll need the atmeldrv system file and the XpAtmel.exe in the same folder to flash it. I popped 2 289 icams mounted on wafer boards with it. 289 is equal to a 109 rev. My opinion it is the best script out there. Good luck
