Nalin, are you going to update ?
Username: Espn3
Post Number: 267
Are you going to update your public.box.net-2500_full_kit with the latest code for PUFF ? thanks.
Username: Nydas
Post Number: 10794
Version 268
Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included.
Either b75 or PUFF
http://public.box.net/2500_full_kit
You must select whether you want to have the old b75 files or PUFF files.
If you have b75 boot and want to use the PUFF BINs , you must convert to PUFF boot
If you have PUFF boot and want to use th eb75 version, you must convert to b-75 boot
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Username: Nydas
Post Number: 10803
Tronics has automated the conversion of BIN process and has come out with excellent BINs
Username: Psychmonster
Rhodium Member higher
Post Number: 834
for all you lazy complainers...just click on any old Nalin Box and save...then when u reclick after new bins come out its updated...magic
Username: Gregraf
Post Number: 656
Nalins Box will fry your box
Username: Master_lee
Post Number: 52
Hey RAF my box has fried your mama box
sorry about that. your mama HAD SOME BAD PUSSEY.
