For Nalin Nyda
Username: Vicb
Post Number: 52
i got my quaity back up to 97 did a facorty default re-loaded all files... still just rolling on my viewsat .
by the way nalin in my antenna settings should my 22khz be: on or off for echo 7 & 8???
Username: Vicb
Post Number: 53
nalin could it be my transponders??
i live in south florida and echo 7 says 12224 so does echo 8 12224
should they be different??
Username: Pleasersmiles
Post Number: 34
Slick:
Although my DN is not presently working.
PANSAT 3500SD (Secure Digital) Receiver
Menu/Installation/Pass/SatSetup
SAT: Echo7@119
Standard 11,250
Off
DiSEqC #4
None
SKEW 0
12224. V20.000
1.2
Scan: All
SAT: Echo6,8@110
Standard 11,250
Off
DiSEqC #2
None
SKEW 0
12224. V20.000
1.2
Scan: All
Trust information is helpful
Username: Vicb
Post Number: 57
thank u
Post Number: 35
Slick
As you can see, I'm a newby, too. One thought: Is your Autoroll "ON"?
Menu/ParentalContol/SecondPin/Autoroll/Select On
Although my autoroll was "on" before, currently it was set to "off".
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2101
Keep autoroll on
you need it for roll new keys
Username: Vicb
Post Number: 58
trust me it is on .. this has been happening since thrs. if i leave it on autoroll it will eventually turn on after a few hours.. tha ks anyways.
Username: Plymouth
Post Number: 2102
110 12326
You need it just for be sure you are on good sat
No need it for autoscan
Username: Kirankumar
NO Bashing
Post Number: 2659
do this and it will work
all receivers are up on DN
b@v is down,locals are up,wait for new fix
for people having problem getting dn
do a hard reboot,make sure auto roll is on
then leave it on any one channel until picture comes up,it may take up to 10 minutes
do not keep changing channels until picture comes up
Post Number: 37
African
I reinserted BIN/Hard Reboot/AutoRoll ON/Left on one channel for 30 minutes with no success.
Can change to
119 12486/110 12326
Press OK as instructed.
However, both sats return to: 12224
Pansat 3500sd Receiver
SAT: Echo7@119
Standard 11,250
Off
DiSEqC #4
None
SKEW 0
12224. V20.000
1.2
Scan: All
SAT: Echo6,8@110
Standard 11,250
Off
DiSEqC #2
None
SKEW 0
12224. V20.000
1.2
Scan: All
Suggestions?
Post Number: 38
African
BIN 379-a
NO Bashing
Post Number: 2663
try hooking up one of your satellites directly to receiver,bypass the switch using a coupler
and post results
Post Number: 39
African
Sorry for wait to respond (Had to buy a coupler.)
Outside:
Hooked up satellite cable 6,8@110/coupler/Receiver.
Inside:
Reconnect cable to receiver/Turn on receiver.
Installation/Antenna Setup/
Standard
LNB 11250
22kHz Off
DiSEqC #2 (even though it's not hooked up
Legacy SW None
Skew 0
TP [23]12516 V 20.000
Position Setting 1.2
Satellite scan All
Level 75+%
Quality 92+%
Exit to channel. Wait for picture/
15 minutes later still counting.
Suggestion/s?
Advanced thanks for assistance.
Username: Realtorkim
INDIANA United States
Post Number: 75
Thanks All for info Pansat 2700 Changed nothing only re-boot from reading all of your recent posts. Your Great...
All working just fine. Talk soon
till next time lol
Thank-You
Username: Kocsuckercartier
Post Number: 20
Username: Lklies
Post Number: 28
Kimberley... New ECM since yr last post.
Enter 0101 and 0901 keys manually, if U have to.
