2500/FLU to 2700 - Version 250
Username: Nydas
Post Number: 8147
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest Lothario_250 for DN and BEV fix. also available separately
The All_249-2.zip has all the 249 conversion files separately as well
Some jtag files are also included.
The full kit is in full_kit250A.zip or later. Download the kit and unzip in a new jvvh directory. Read the instructions in the Instructions.doc file.
http://public.box.net/2500_full_kit
Username: Luv2meet
Post Number: 37
Nalin, I have tested them all; the AV 250, lothario 250 as well as the jvvw and none works on b3v. What I have is a flu converted. Can you confirm please? tia
Username: Jwl1
Post Number: 174
Nalin, Thanks for the clarification, as always.
Username: Nydas
Post Number: 8148
All reports indicate that the conversion BINs 250, do not work on BEV. I suggest the following for the BEV people.
Write down your antenna setup.
After loading the bIN, do a system default followed by User setup - date/time etc
switch off at back and on again.
Do antenna setup for one BEV sat only.
Do a blind scan.
Switch off/on
Rpeat with the other BEV sat,if you have it.
Then do the DN Sats.
Now keep on the favourite BEV channels and switch off/on. Wait for autoroll.
Please report if you do get BEV.
DN is working fine.
Username: Ntns
Post Number: 7
Does it fix PPV? I have uploaded this file to my reciver FLU 2700 and I have all regular chanels except I don't have any PPV.
Username: Nydas
Post Number: 8154
You should get PPVs on Echo 8.1 (110W)
Username: Ntns
Post Number: 8
For some reason I am not geting any. I will reload bin and scan everything again to see what happans.
Thanks Nalin
Username: Nydas
Post Number: 8155
I am testing DN using
Saif_Bin_250 (Alienware).bin
on a converted Pantec.
It loaded well, took the old channels from channel master and worked immediately.
I haven't tested BEV, because I am not scanning it.
All PPVs and Internationals are there.
Username: Way2smart
Www.desifta.tk
Post Number: 1262
nalin can you please help me
Username: Nydas
Post Number: 8158
The $mart 1! : What's the question?
Username: Way2smart
Www.desifta.tk
Post Number: 1264
https://www.ecoustics.com/electronics/forum/home-video/449253.html
Username: Destine0429
Quebec Canada
Post Number: 450
Does the bin
CS_250T_lightning_100t_Series
free your remote? Or is it working fine on Pansat Remotes?
Username: Metallica
Post Number: 115
Julie this 1 it is working fine for my remote..
CS 250T Lightning without remote issue.
i got it here.
http://www.ftabins.net/forumdisplay.php?f=128
Username: Nydas
Post Number: 8177
Saif Conversion BIN 250 is flawless.
Lothario and CS_250T are pretty close.
The (F7) BINs have some freeze ups and the Remote usage is not 100% with some people.
All Conversion BINs are available at:
[link removed]
Username: Luv2meet
Post Number: 39
Nalin, are these bins still for DN only? tia
Username: Kjniceguy
Lethbridge, Alberta Canada
Post Number: 126
Nalin...are the SAIF bins for my pansat 2500a converted to 2700?
Username: Aissa_h
Post Number: 16
before ask please read threads the answer is there
