Gold Member Username: Saqeeb9000Post Number: 1858 Registered: Oct-07 | ok guys nothing scary.. everything is working good.. just i cannot check sw version check.. or upgrade it.. is something goin on (may be new bin is comming).. any one have same problem or is it just me? |
Bronze Member Username: Kart_57South Florida Post Number: 54 Registered: Jan-08 | I would not use IKS when stand alone boxes are working, use Nfusion when stand alones are not working as a per caution. |
Silver Member Username: ScabzKnoxville, Tn Us Post Number: 362 Registered: Oct-07 | Is there a way to get the nfusion to work any at all disconnected from the net ? |
Silver Member Username: VittuPost Number: 130 Registered: Oct-07 | I don't think so. I leave it connected. |
Gold Member Username: Saqeeb9000Post Number: 1860 Registered: Oct-07 | scabz..iam not really sure but cartier1 was saying some thing .. check the ohter post.. how to installin nfusion.. |
Silver Member Username: ScabzKnoxville, Tn Us Post Number: 364 Registered: Oct-07 | When I bought my nfusion I thought that it only had to be connected during a bin change. I didn't know it had to be connected at all times. I will look it up. |
Gold Member Username: Saqeeb9000Post Number: 1895 Registered: Oct-07 | https://www.ecoustics.com/electronics/forum/home-video/439777.html look at this thread scabz.. cartier told me about this bin compatible with nfusion.. i wanna let you know that i din't tried it.. if you wanna do it goahead and post results.. |
Bronze Member Username: FattayPost Number: 27 Registered: Jan-07 | I seen a add for Nfusion ,stateing that it was an HD recevier. Is this correct,something new, or are they hittin the crack pipe? |
Gold Member Username: Saqeeb9000Post Number: 1905 Registered: Oct-07 | no not hd ..... i have it and i have hd tv.. its not hd.. may be u are talking about neusat.. |
Gold Member Username: Saqeeb9000Post Number: 1906 Registered: Oct-07 | show me the add.. |
