Viewsat ultra help with bin PFTAUSW-080114U
Username: Bowgator
Post Number: 9
I loaded new bin from total fta and my view sat said caution: do now power off, about 10 mins went by and my daughter flipped the light switch and bam the power went off. Now I have a black screen and on the front of the box there are 4 green dashes, dose anyone know how I can fix this?
Username: Madflea168
Post Number: 32
try to get the bin from other sites, they are all over the forum.
try to do a factory bin then the lastest bin again.
Username: Rtf
Post Number: 32
Rich you will be OK if you reload the correct file using the serial com port on the rear of the machine. You will not be able to correct this using USB port.
Username: Dafidof
Post Number: 38
I had the same problem one week ago, I had lose the antenna settings, try to verify this, and make sure your Signal Quality is there. Then do an auto scan, at this point you must have all the channels and it remains just to load and other bin from an other site than total/thetotal.
Username: Jayson
Post Number: 76
you will have to install factory bin........then install the latest Jan 14 2008 bin........stay away from total/thetotal.........the best scenario is what Richard told you......dafi he will not be able to check the settings with a black screen.......
