BIN 234 PANSATS
Username: Majk
Post Number: 22
BINS 234 WORK GOOD
EVERTHING OPEN BEV AND DN
LIKE THIS
GO ON ALL CHANELS AND PREES WHICH YOU WANT TO WACH
NO FROM FAVORITES
ENJOY
Username: Hamid9272
Post Number: 29
ok are u sure ?? every channels are working or only a few ?? and where can i get the 234 ?
Username: Psychmonster
Rhodium MemberAint nuthin ...
Post Number: 497
234 bin for conversions does not work...be careful what you post
Username: Hamid9272
Post Number: 30
deki is a piece of Sh!t
Username: Majk
Post Number: 23
For conversion receivers use JVVH 234
EVERTHING OPEN
ENJOY
Post Number: 498
I just ran that and it rolled to 600% and then scrambled
Username: Majk
Post Number: 24
Turn AR off and tp update off
Works well
Post Number: 499
just loaded 231 bin and back to where I started..every other channel works
Username: Aissa_h
Post Number: 10
are some channels on BEV scrambled??
Username: Machedonul
Post Number: 304
im running 235 and all DN is down
thank God for globecast at least...
Username: Charjam
Post Number: 292
i have bin 233 on my 2500 working good bin 233 jvvw that is
Username: Cartier1
Post Number: 1656
is jvvh 232 working for dn? anyone has converted pansat 2500 . someone is asking for help but i dont have the 2500 thanx
Username: Charjam
Post Number: 293
mine is a converted 2500 and the 233 is working fine i guess the 232 would work also
Username: Thakkar2000
Post Number: 164
232 just went dead i think
Username: Perycles2005
Post Number: 54
Please some one direct me to where I can get jvvh or CS 233 for a converted pansat...thanks
Post Number: 55
Hey David can you direct me where to get the 233 bin for converted pansat...thanks
Username: Daddydawga
Post Number: 18
Im useing bin 232 everything stiil up
Username: Luv2meet
Post Number: 11
Here are info Nalyn have posted couple of days ago for 232 and 233 bins..
For Pansat 2500/FLU new conversions and converted to 2700
Use only on converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
The latest ECM of 10th January, requires that you use the 232 or 233 BINs.
These have been posted separately in Conversion_232_233.zip file.
http://public.box.net/2500_full_kit
FOR FIX dated 10th January, 2008.
Post Number: 518
231 232 233 all the same...
Username: Zezator
Confirmed - deki is right,dn,bev,gc are working with bins 234 and jvvh 234...
Username: Hamid9272
Post Number: 31
okkk then could u guys post a link where we can get 234,,, tanksss
Username: Majk
Post Number: 25
Fortec Files » Jvvh_Original(BG)_234_GC.zip
Here you go
Enjoy
Username: Majk
Post Number: 26
http://www.ftamafia.net/forum/attachment.php?attachmentid=379&d=1200160785
Sorry here is the file
Just register and enjoy
Username: Nydas
Post Number: 7067
Pansat 2700
As of now DN is working fully well using BINs 231,232, or 233 and even on 234.
BEV has put a different type of ECM causing 231-233 BINs to work properly on even channels and 235 to work on odd channels.
Similar situation has been reported on C00LSATS and Pansat 3500s.
Username: Nydas
Post Number: 7068
If you are looking for 2500/FLU to 2700 conversions BINs, go to
[link removed]
