I'm trying to install the latest 218 bin file to the Pansat 2700A box but it says downloading and doesn't do anything. The cable is a null modem cable that have always worked. Is the box gone bad?
latest bin is 220... 219 works too. try changing the com port in ur bl loader program. if that doesnt work, try deleting ur com port on pc. right click MY COMPUTER- go to MANAGE-DEVICE MANAGER- PORTS-COM PORT- right click-UNINSTALL-right click ports again-scan for hardware changes
Thanks dantetn, I tried all; 1. changing the com port but port 2 and 4 gave error and port 3 same as port 1, stayed at downloading and not doing anything. 2. uninstalled com port 1 and scanned for hardware changes but still same problem.
wow, I havent seen one that wont take the load. What loader do u have?? Exact name. Also, there is a zmodem file that comes with the loader. U can open it using the loader program. or copy it to the system folder on ur c: drive.
I need some help here i converted the rec i have and loaded all the bin and boot files and it worked ok but the bin file i tried the 218 did not work my box does'nt work with my remote it stays on the "on " position and wont change .so i tried bringing it back to its normal state as a 2500 and now i have "b75" knight riders on it what do i need to do?
