Pansat2500-X-85BL_071016_299 Tivo_api
Username: Greatful
Post Number: 45
what does this file for the Pansat2500a
thanks,greg
Username: Greatful
Post Number: 46
what does this file do for the Pansat2500a
thanks,greg
Username: Satgrl
Post Number: 225
i tried that stupid file from ftabins all it does is changes the background on my recever u noe the background thats in the menu screen hahahahah its stupid
Username: Dr_dss
Post Number: 101
Does a lot more then that. It's setup for tivo. Which I'm willing to bet you have no use for.
Username: Satgrl
Post Number: 235
true true
Username: Dr_dss
Post Number: 102
See! so before you goes and bad mouth others hard work stop for a sec and ask yourself is this message going to be considered another Neurotic one :-) if so then use backspace it's your friend. then try using er0tic overtones in your message.
Because you get more Bees with honey then you do with vinegar.
Username: Greatful
Post Number: 47
so i can record with this box now?
Username: Dr_dss
Post Number: 106
Record in what sense?
Username: Lklives
Post Number: 13140
That bin is simply the old 293T bin renamed
