Does the keys have changed??
Username: Scasta007
Hi,
I just want to know if there is new keys, because I have a Pansat 2700a and I can't see anything.
Thanks
Username: Mrskullz1
Brooklyn, New York
Post Number: 404
what do you mean you cant see anything? is the receiver dead? as in no lights are on when the power is on?
or does it say scrambled or bad channel?
if anything...check for the latest keys in the 'New Keys' thread on this forum.
IF you already have latest keys, then try a reboot of your receiver. Turn it off from the back and turn it back on after a minute. It should be fine after that.
Then grab a beer and enjoy :-)
Username: Scasta007
Well it says scrambled or bad channel and i have reboot the receiver. It's been like that since yesterday
Username: Mrskullz1
Brooklyn, New York
Post Number: 406
did u check the new keys thread and input the latest keys?
Username: Mrskullz1
Brooklyn, New York
Post Number: 407
ok...and if ur keys are good...then jus do a fresh scan of ur sats
tp's change over time
Basically....do a full factory reset and then rescan ur satellites. That should bring ur channels back.
BTW...wht is ur signal strength and quality? Are you using a switch of any sort? It could possibly be a shorted switch so if you are using a switch of any sort..disengage it and directly connect your wire from the lnb to the receiver.
Username: Scasta007
I found new keys, and it worked, thanks
Username: Mrskullz1
Brooklyn, New York
Post Number: 410
