Pansat 3000
Username: Ikaleem
Post Number: 88
Can someone help me out....Someone has given me a Pansat 3000 to program. Can someone let me know what receiver clone is this of from Pansat line
Thank you
Username: Ikaleem
Post Number: 89
Also if I update to b75 boot file is there a clone kill in the file?
Username: Lklives
Post Number: 9414
its a Pansat 2500 CLONE...and no , the 2500 does NOT use the b75 boot upgrade or any boot upgrade.., thats ONLY for the Pansat 2700 and its clones..and the b80 boot for the Pansat 3500
Just do as U normally would...just upload the latest 2500 clone bin (293T) and make sure the keys are correct and antenna/dish receiver settings (LNB type, freq 11250, disque port settings etc) are correct..
Username: Ikaleem
Post Number: 90
Thanks Man. Does it not have autoroll?
Username: Ikaleem
Post Number: 91
hey LK can you send me the last clone safe bin if you dont mind or send me the link
Username: Lklives
Post Number: 9417
yes it has autoroll A/R
http://www.dsstester.c*om/details.php?file=2512
remove the * in link...
Username: Ikaleem
Post Number: 92
Damn this thing is really bugging me now. Is the wire for Pansat 2700 different from 3000? I am trying to upload the bin but cant it just goes to the channle number and nothing happens....
Username: Lklives
Post Number: 9482
yes they are are different cables...the 2700 uses a null modem...the 2500 clone (3000) uses a straight cable...they look identical..
