Directv triple Lnb dish
Username: Khopadi124
Hi, Can any one tell me that Directv triple Lnbs dish will able to get 110, 119, 121 dishnetwork signal for fta model pansat 2700A and 2800a and do I have to use fta switch or does it has a built in switch that can be use. Some one please explain in details. Any info will be helpful.
Thank you.
Username: Lklives
Post Number: 9218
use the SEARCH feature here...phase 3 DTV dish...been discussed here 5000 times..Go read!
Username: Tapeman
New York City in-HD, NY
Post Number: 1117
with those 3 LNBs
- you'll eithr get 110 or 119 but not both
- with carefull skew at most you'll get 91 and 110 if you point to 101
- Middle LNB won't get more than 3 TPs
- 2 sats only from 2 side LNBs
What I will do strap a legacy LNB on top of middle LNB as a replacement. This can get you 110/119 >>> 2 wires to DISEqC switch. One from either output second from added legacy LNB point middle LNB to 110. This is the only way to get 110/119 from those triple DTV LNBs
thank you king for the info.
