Missing all indian international channels
Username: Kach
i just uploaded the new 289t bin and scnned all channels and now all my indian channels are missing...smoeone help plsssssss.
Username: Ryersonresurrected
CANADA Charlatan...
Post Number: 684
Username: Tapeman
Post Number: 434
Man what is going on with international channels?
289T if compatible with your receiver may have few bugs.
Try to turn off receiver from back switch, wait about 1 minute then turn it back on. It should fix the problem (don't change channels) If it happens again it probably bin PGM got some bugs.
The genius people that write memory locations put wrong address. If they work for me I would of fired them long time ago
Username: Kach
i turned it off and on after 1 minute...still no international channels...
Username: Tapeman
Post Number: 437
- Turn off auto TP (you only need this on when changing setup)
- Make sure auto roll on
- tune to a channel you want to receive
- Turn off receiver for 1 minute
- Turn it back on and leave it to roll (5 to 20 minutes)
Username: Nydas
Post Number: 1531
Jamla: You may have to reset your list of satellites you are scanning, connect properly with DiseqC switch and do a blind scan
Username: Crazy_greek
Post Number: 513
Hey jamia
You will find Indian channels on these
Satellites, EchoStar 61.5,118,121 and 148.
Intelsat Americas 5 @ 97.oW.
Nimiq 2 @ 82.oW.
Now could you tell me, what Bird are you
on, with these missing channels?
Maybe I could help.
Username: Nijhers
Post Number: 22
hi guys
i have the same problem i did same as describes but still some channels are missing and some are comming
i have ariza 700 on 148n
Post Number: 514
harmeat
Check each of these TPs for Quality
Signal. Freq. 12224 (Pol.V) SR 20,000 (tp1).
Freq. 12370 (Pol.V) SR 20,000 (11).
Freq. 12574 (Pol.V) SR 20,000 (tp25).
You will find your Indian channels
on these TPs. If the Quality Signal
is above 50%, just do a TP Scan for each TP.
Username: Nydas
Post Number: 1544
There are two different issues here.
Jamla has a 289T Bin and is missing Indian channels. Jamla, you should be getting all the Indina channels, particularly SET SETMX, ZCINE, ZEETV, B4U.
Harmeet has Ariza 700, so he would be missing the above channels but should have at least ZGUJ, SAMAY, HT, etc.
There is no new BIN out for Ariza 700, equivalent to the 289T.
Username: Gigolo72
Post Number: 61
I am also missing some of the international channels, I have viewsat Platinum, do i have to load a new bin ?? cause blind scan didn't fix the problem!!
Anyone help is greatly appreciated.
Username: Hanz
Post Number: 228
Fred, a new bin is the only way to retrieve the international channels. Make sure you get the correct bin for your receiver.
Username: Charlie40
is there a fix for atmega to bring back indian channels I am getting some but not the main ones (ztv, sony, b4u, zcine etc)110 working good
Username: Kach
Kavin Reno: i scanned nimiq2 @ 82.oW and echostar 61.5
still no indian channels...
(receiver pansat 2500a - bin 289t)
Username: Ismailbawa
Post Number: 10
hi ppl i have this problem i been missing indian chanels for week now i have ariza xtream receiver if any one can help. help is gretely appreciated and even if u guys can not help i still would like to thank you for great work u guys have been doing so thanks again and i hope some one will be able to help me out (really want see indian channles plz help)
Username: Ke5aqn
Post Number: 792
Ok I am not trying to be mean here but, if those few channels are so important just make it easy and get a Viewsat.
Username: Charlie40
how reliable is viewsat extreme? I have heard good things about it and
was thinking of getting it myself. I like to watch cricket mostly and
indian channels would make the lady happy. currently I have atmega until
2 days ago all 110 channels were working also cricket on 457 but
nothing now so I was wondering if viewsat extreme is consistant?
Post Number: 534
jamla
Go here, Post #361
https://www.ecoustics.com/electronics/forum/home-video/310797.html
Username: Nassa
Post Number: 89
My international channels on the viewsat xtreme r also not working?
Username: Ke5aqn
Post Number: 796
nassa,
http://totalfta.com/showthread.php?t=36768
Post Number: 11
bro THE FTA TESTER is there any wahy i can see dam indian chanells on ariza xtreme plzzzzzzzz help and ya i no u would naver be mean bro, if u were mean person u would naver be here helping this many ppl. thanks
Username: Sniper66
Post Number: 40
i am havin the same issue on pantec...i downloaded 289T bin...and i am getting no channels now..even after entering the right key...All channels are scrambled
Username: Nydas
Post Number: 1623
sniper66 : The autoroll probably did not work.
Set autoroll off for BEV and for DN. Do "Set default key". Then enter both Key 00 and Key 01 under Nagravision 2 and appropriate Provider ID - 0101 for DN, 0901 for Bev.
Make sure you save. Then After exit, turn receiver off at the back and turn on after 30 secomnds.
Username: Nvs
Hi Nalin, I have Eagle Star receiver i believe its a clone of Panset. I have tried putting in the keys which are provided in other threads but they dont work. Can you please update me with the new key if possible. Also in my autoroll option i have all the options ON is that okey? thank you.
Username: Nydas
Post Number: 1656
Ricky S: You need BIN 289T and then do manual entry of keys as stated in my post just above yours. Follow the instructions fully and it should come on.
Username: Saad_sajjad
HI nalin does 289t work for fortec classic also?
Username: Nydas
Post Number: 1668
289T does not work on fortec classic
