Bronze Member Username: HellboyFg, Gf Aa Post Number: 12 Registered: May-06 | can some one tell me how to download new bins and what's STB MODEL? i am trying to fix my ariza but i am struggling. please help |
Bronze Member Username: QbeePost Number: 34 Registered: May-06 | stb = set top box. I have a c**lsat 4000 - so my stb model is 4000. But I think you are maybe looking for the stb tool which is the software that you use to download the bin from your computer to your stb. Try reading here - http://www.d**tester.com/files.php?cat=3 (replace the "**" with "ss" when typing in the url) |
New member Username: SlimmazPost Number: 1 Registered: Jun-06 | can someone please tell me how to download the GT Rom im having problem setting up the new sysem i am a newbie. thank u. |
Silver Member Username: The_wank_artistPost Number: 853 Registered: Feb-06 | go to dsscentral*net and get the rom loader from there. Save it to your computer and open it there. It stays on the computer and you use it to interface between the computer and receiver. When you finally get it saved, you'll need to select the receiver model, and select the bin number. |
New member Username: WisbangInwood, Ontario Canada Post Number: 1 Registered: Jun-06 | can anyone give me instructions on how to fix the orginal pansat 2500A thanks |
Silver Member Username: The_wank_artistPost Number: 868 Registered: Feb-06 | Load the 2500's new bin. Let the auto roll work, and watch tv. Get it at dsscentral*net. |
