Dish setting
Username: Jcgarcia
I have a Pansat 3500 sd, two dishes each with a dual LNB (12.2 Ghz-12.7Ghz) in the LNBs label. I got a disqecswitch 4x1(Pansat) I flashed the last bin (141). I got about 77to 80% signal but 0% quality. Maybe the answer is in some thread but I have read a lot, even the archives but haven't found the answer. I am trying to get 110 and 119. What might be the problem?
Username: Lklives
Post Number: 952
U don't have dishes aligned correctly at the 110 and 119 birds..
Username: Jcgarcia
Ok, Thanks
By the way I've learned a lot reading your answers, specially when you answer the same over and over to people asking the same. Just for the record, does it matter the frequency on the LNBs? Will the resulting signal be in the range of my Receiver?
Thanks, I'll keep reading and learning.
Username: Jcgarcia
I ask because I don't see that frequency in the LNB settings for the Pansat 3500sd, unless I imput them manually, Or I should forget about it and jut leave the default 11250 for the Birds?
Username: Lklives
Post Number: 955
Username: Jcgarcia
Thanks LK, pointed the dishes right and everything is good, I'll keep reading and learning
