Programers
bobcobb
will a detonator 2 work to program bev cards
If U can mod it into a iso..
bobcobb
can you mod into a iso?
Username: Lklives
Post Number: 975
some people can..it was popular 2-3 years ago..no more..
listen if U want to program cards ,then go to another DSS site..this site is mostly FTA receivers, not plastic cards....problem is many sites do NOT allow Bev talk!...www.dsscommunity. com does...but must type Bell not Bev..and they have an area for plastic cards and Bev...most people do not do Bev with plastic, they do dishnet..DN gets twice as many channels as bev..and is considered much better...bev is the bottom of the barrel on the sat list!..
bobcobb
is there a flash to make it an iso progamer? if so where
Username: Lklives
Post Number: 979
HOW TO PROGRAM YOUR CARDs WITH YOUR HU LOADER
HARDWARE
1> Standard Unlooper
2> Computer running Win9X, ME
SOFTWARE
1> EchoLoader
2> NagraEdit
Use EchoBoot in DOS to program your Atmel 2313 in your HU Unlooper. Once this is loaded the Unlooper now becomes an iso programmer.
READING CARD
1> Start Echobox112233 in a Windows DOS box.
2> Hit R: Read card
3> Place card in the unlooper when prompted.
This will create an image of your CAM in the same directory as EchoBox112233
tiers+blockers
1> Using NagraEdit open the bin you saved from your card
2> patch eeprom with tiers and blocker
3> make sure ird, boxkey, ird status 09, zip, time zone are all correct and save as a bin file in same folder as EchoBox112233
WRITING BIN
2> Hit L: Load from Bin
3> Enter file name of the BIN you just created in NagraEdit
4> Insert card when prompted
I would recommend that you dump the card
and verify that all writes are complete and accurate.
I already told U were to go...maybe U should listen once in awhile!
