Please HELP Pansat 2500A
Thx
Hello Guys
Please Help
Got Pansat 2500A, downloaded the latest file which is X-85BL_060203_271_au_api(N).bin. Downloades complete, plug back in TV. Well it keep on "Waiting for Picture" the percentage goes up and then start over again. I assuming it autorolling over and over.... Please tell me what I need to do.
Username: Lklives
Post Number: 580
set default key OPTION..and don't ask me how?...read the Pansat setup guide here..
scarberia1
If after you set the default key (parental control > second PIN > Set default key "then hit ok") and still it does not work after 10 minutes then I recommend loading bin 271t. If you have a genuine 2500a then use 271t, if you have a clone then just use 271. Happy viewing.
12456877
how do i instal nagra 2 or 1
12456877
how do i install nagra 2 or 1
Username: Lklives
Post Number: 587
U must buy a nagra machine at radio shack..they come in different sizes and colors..
Username: Lklives
Post Number: 588
BTW...271T is for clones and 271 bin is for genuine Pansat 2500's..
Username: Abj
Post Number: 11
you mean vigra machine ????
Username: Abj
Post Number: 12
Viagra machine, thats what I meant to say..
Doesn't that convert it to nagravision2 after you use it???
thx
Hey guys
I did set it to default, still does the same thing. I know you told me to download 271 file. Please give me more detail on file name because I did download this one which is 85BL_060203_271_au_api(N).bin. Please advice
Thanks a lot
Username: Lklives
Post Number: 599
then wait for the keys to roll (maybe 20 minutes or longer)...patience!
Username: Akshatbpatel
hello..I am new and I have a Pansat 2500A..it has been working fine until recently when it starts to say "Wait fo Picture!!! [%]". When I do get a picture, it freezes and it doesnt come back. the picture comes from time to time but does not stay constantly like it has when I 1st got it. Please help me
Username: Lklives
Post Number: 606
peter...are U stupid too?...read above and do as above..
I dont understand all that
do I need to download to program ? I dont know crap about this
do I need to download the program too? I dont know crap about this
pe
then subscribe for you to understand ???
Username: Abj
Post Number: 15
go to a site where you can be helped.
You will have hardtime with this if you don't understand anything about this.
pantecf2a.com
how can I make my singal strong so I dont have to keep going and changing it to make the quality a higher percent
Username: Abj
Post Number: 21
what are you changing to make quily a higher percent ???
Post Number: 7
installation > TP
Username: Abj
Post Number: 22
in antenna setting, set your setting this way.If youare try to get echo 7--119w.
Lbn type--standard
freq.--11250 22khz-off
disq.---if you are using disq. switch---#1
skew----do not touch
tp-----do not touch
positioner---disable.
press exit button, will ask you to save setting? press okay.
do the same for echo6,8
if you have disq. switch---#1 if not leave it alone.
After you are done saving both, go back to installation and scane each satellite one at a time.
Username: Abj
Post Number: 23
Lbn type--standard
disq.---if you are using disq. switch---#2
tp-----do not touch
Post Number: 8
thanks..but the darn wait for picture thing is back and then the picture comes and freezes..do you know what to do for that?
Username: Ajb
Post Number: 36
turn off back of your receiver and wait few minutes and turn it back on and see what happens
Buy new receiver, DreamBox DM7020-S
jillyah
hey guys im using the 271 au, did the setup justice instructed, i can get a pictuer for maybe two mins and then jst goes back to "wait for picture" also i'm missing alot of ppv, what i do?
Username: Abj
Post Number: 27
you might have to reset factory setting,reload 271,start the process over.For whatever reason some receiver will not load new bin sometimes without loading the factory bin first.Before you do that how long have you had tv turned on.Sometimes it might take awhile for the auto roll to kick in.try put the keys in manually .It just jump start the program.
dishnet work keys
00-9e 5b 7a 77 c0 fe 91 ca
4d 2a dc 33 d4 cd e3 75 <<future keys
01-fb d9 f2 d9 d6 c9 ef 7a
57 ad 32 24 67 42 6c e6 << active keys
Post Number: 9
I tried changes codes but it always becomes euskelitel as defualt? instead of Dish network. wahat do I do?
Ok, heres for all those stupid ppl out there with pansats -
1.LOAD THE BIN ONTO THE RECIEVER.
2.SCAN FOR CHANNELS
3.RENAME THE SATELLITE(IE. Dtv channels, Sat 1, Sat 2, etc...ANYTHING U WANT)
4.Go to parental controls, go to second pin and press 0000.
5.Go to nagravision and set the current keys OR
6.do this only if u have this option, - Go to Nagravision 2 after u press in 0000 for second pin, and put in the following keys for 0101 Dish Network(ACTIVE NOW)
00 - 93 5B 7A 77 C0 FE 91 CA
4D 2A DC 33 D4 CD E3 75
01 - FB D9 F2 D9 D6 C9 EF 7A
57 AD 32 24 67 42 6C E6
7.(6) Watch T.V.
Now these are steps to make it stop saying Waiting for picture. %, stop rebooting itself, and stop you from any other problems you might have. Unless you just have ur satellite set up wrong.
I am a noobie myself and learned this stuff in 3 hours of research. I hope u noobies don't ask anymore questions concerning these issues anytime soon cause it took me about 10 mins to do this lil tutorial.
Post Number: 10
I am reaaly a noob..How do I load the bin?
Username: Abj
Post Number: 28
go to dssrookie._ _ _ and read in pansat section. It is all there on the rookie how to section.....
Post Number: 11
could you give me the site?
Username: Abj
Post Number: 31
Peter,
I just gave you the site in my post dssrookie.*om
* is actually stands for (c)
Username: Lklives
Post Number: 609
New Pansat bins released today .. with autoroll fix...go get em..they're everywhere...notice the date..11 Feb on files..
Pansat 3500 X-05BL_060211_141eubx_au_api auto fix!
Pansat 2500 X-85BL_060211_271_au_api(N) auto fix!
Pansat 2700 X-87BL_060211_144_au_api auto fix!
Post Number: 12
how do I put a bin in the reciever? how do I get bins?
158965
im giving out a rewardto who ever helps me . please e-mail me at (sandoval2633*comcast.net)
* means (@).
158965
is there a way to get nagra2 from the internet for free.
Post Number: 13
when I put the bin in the loader and download it all to the reciever do I have to do anything after that?
Username: Lklives
Post Number: 614
peter...U are too LAZY and go to a DSS site and READ a newbie FTA manual which explains all your questions...so I suggest U SUBSCRIBE!...this is like trying to teach algebra/trig to a kid who hasn't learned how to add or subtract yet!
Post Number: 14
I dont evenknow where that site is!
Username: Lklives
Post Number: 620
Take your pick!..
Final Solution Free To Air:
[link removed] (Pantecs,all clones and all receivers)
[link removed]
Post Number: 15
thanks
Post Number: 17
I cant seem to find what to do oafter I downloaded the bin on to the reciver? can anyone hook me up with that link or can tell me?
Username: Dannyboy88
Post Number: 8
hey LK i was wondering i have pansat 2500 and when i go to enter the keys for bell i can enter the 00 keys but when i go and press right or left to get to 01 it wont switch it just stays at 00 is there a way to add 01 into it??
Post Number: 20
2500a epg problems
ever since i had my pansat 2500a ive always had a problem with my epg...the time is set, the right time zone is set and i still dont get a blank epg and only after a lil waiting on a channel i get just the info of that channel and in the epg it just shows the current show and the show directly after it...is this normal or should i be able to get a full epg?
where can i get a ppv schedule (time, channel)
pe
call DN and ask for a copy of their PPV sched
Username: Lklives
Post Number: 637
Peter..with pansat, all U get is a 2hr EPG..and are U hitting the INFO button?...also make sure the Date 2006 is correct,along with time zone ,date and time..
Post Number: 11
hey guys im having some other issue now and the problem is when i do enter the keys for both 01 and 00 and save them both my pressin ok than i exit it and it says scrambled so i go and check the keys and everything from the provider ID to the Key data is FFFFFFFFFF is there anything i can do
Username: Trucker
Post Number: 22
"daniel" if you got the latest bin loaded. all you should have to do, is set the default key. good luck
Username: Xeni
Hamilton, Ontario Canada
Help i got new keys and nag 2 and every thign but im getting wait for picture and just kees goin 10 % 30 % and keeps goin any one got any info y this happend plz help me
Email me at xeni2@Msn.com
LK - How often does DN change the keys?
Is there some pattern?
Username: Lklives
Post Number: 651
There is NO pattern for DN key changing..it varies...I believe 20 Jan ( 3 weeks was last time)...sometimes 2x in a week and sometimes 1x a month or 2 months..
Username: Farthead
pansat 2500a uploaded the codes, get certain channels with no problem. can see all the channels in the guide. some say scrambled or bad, however. is it because they're pay channels-and is there no way to remedy this?
What is happening to my pansat 2500?
I have been reading for awhile today, and I havent heard about my problem yet.
119 completely scrambled.
Quality is 85
other #s good also.
I dont get it.
I have re-scanned, new bin (271) channel delete. reconfigure box.
And checked all connections.
Thought it could have been disque switch, but how could that be if on scan, all channels show up.(on 119)& 110?
There are alot of intellegent people out here, but I guess i am not one of them. Please advise on what to do. Thank You in advance
Username: Lklives
Post Number: 662
Just what is your problem and point?...U never said!
Username: Lokoz
Post Number: 8
if i do a factory reset does nagra errases
tcf
I have a sonicsat reciver using a superdish pointed at 110-119, and 121. everything is great on 110-119 but 121 keeps frezing and cuting out. I turn the box off form the button on the back, it workes for a few min and them looses the signal if i was to go to a chanale on another sat it would work fine and when back on to 121 again will work only for a few min befor loosing sig. any ideas as to what could be my prob.
Aln
Hi everyone ,
need help on a pansat2500 clone . its called eagle star. it was working fine with the autoroll until last friday when DN started messing autoroll. i have tried every possible file on dsscentral. files for clones and for pansat work on the receiver. i have used both 271 and 271t but same result. the receiver keeps resetting itself after every 10 mins. Can anyone help me fix the problem .
many thanks
