Easy Pansat AutoRoLL FiX
TryThis
If you already have one of those autoroll bins loaded on your pansat and don't want to go back to old bins without autoroll, just change the satellite name from 'ECHO' to anything else that will stop autoroll for DishNet. Good Luck ;)
lovekoi
bin 143 works fine w/ auto roll for pansat 2700a
Username: Lklives
Post Number: 486
To rename the satellites...
press menu--> instalation-->edit TP/Satelite
press ok on selected sat and rename (to dish 110 or whatever)
are
hey dont try this is the same i already tried
Username: F_t_a_is_back
Post Number: 16
Just flash 143 bin and all will be fine...
Where do I get the 143 bin file?
Works Great
thanks LK
this worked great!
