Archive through July 07, 2005
CUT IT BOY
WALDO-Cut the crap....U were never Bright.....
Your dad didn't call U sunny....U lost your
mind in the bastement of Kneegrows Outhouse
"DOWAL-DOWAL-DOWAL all the day long.........
the professor
Carlos...read 2 minutes before U ask..U might learn something..
X-87BL_050621_108_api(N).bin
size: 786.4 KB last modified: 06-29-2005 )
New for pansat 2700A..faster with EPG which can be found and downloaded from www.dsscommunity. com File Share FTA area..
timbhoy
I keep having to turn the power button off after switching channels as the picture freezes, does anyone know how to correct this. My system is DG6800
Username: Jmill1948
Chester, Va Usa
Post Number: 704
reflash then try it
timbhoy
what is reflash?
Username: Jmill1948
Chester, Va Usa
Post Number: 705
Dish Network: KEY 1 is Active
KEY0: 11 64 6B 2E A5 26 ED 7E
KEY1: 40 B2 B9 7A C2 C1 53 75
Barkley
It appears as though the system just went down. Are there any updated codes available?
Barkley
Is anybody out there that can help with the new Dish Network keys?
Barkley
Sorry folks, my bad. It appears that all I had to do was turn my receiver off and back on from the rear.
Barkley
What's up with that?!
Username: Djgo_42
Post Number: 23
Barkley..thanks for the info..I tried it on mine and I'm up and working. DJ
knucklehead
It appears that all I had to do was turn my receiver off and back on from the rear...
that is called a reboot/reset and is instructed here 1000x in almost every thread here,...U should always do a reset every time U flash a new bin,change keys or having any problems..
frustrated
hey ppl,
got a problem here. I have lost all channels and have rebooted, still have no channels. anyone else having this problem? or do i need new keys?
frustrated and pregnant
ok rebooted a couple more times and it came back in. I have also been losing signal strength intermitently anyone know what is going on?
knucklehead
sounds like bad cable,connectors,or LNB...also some transponders have weaker signals than others
Username: Jmill1948
Chester, Va Usa
Post Number: 706
lnb
Cindy1
Hi would you happen to know if you can use an 18" Dtv dish to get T5 or do you need a least a 30" and what type of Lnb. Could you recommend a dish to look for? thanks
Username: Mikeymatt
where on the key edit do you go to manualy key in the new key codes.Im not sure that im keying them in
the coorect place.If someone could help or show me a
link that i can go to and learn more about the key edit page(channel 8282)i have a pro 4000
Username: Mikeymatt
on channel 8282 how and where do you install new keys for pro 4000
Username: Mikeymatt
when you go to ftacentral.com and download the autoroll
and then load stbtool and then try to down load,it says invaild firmware file. is the somebody out there that can help me.
chicago
dude...changing the keys ,doesn't get any easier than this...if U can't do this,then give it up!
Manually Enter Coo*lsat Keys
1) Go to Channel 8282
2) Use the right arrow to scroll to 111 Nagravision (Dish Network)
3) Enter the keys. Use the Info button for letters A-F. Press it once for A, twice for B, etc.
4) Watch TV
chicago
DISHNET KEYS Current
06-30-05 01:00pm EST
Key0: 11 64 6B 2E A5 26 ED 7E
Key1: 40 B2 B9 7A C2 C1 53 75 ** Active
Still current and working!
Username: Mikeymatt
i need to find out what satellite i need to be facing and how do i adjust it,to make sure that these key codes are working.
Username: Mikeymatt
on 110 and 119 im getting 75%L and 79%Q on both and they are in the green also.but im only getting canda channels,mostly local ones.is there somthing im doing wrong.
You had better give it up. If your getting bev ch's on dishnetwork sats or GO READ.
any new keys?
Unsure
Please pardon my ignorance, I'm new to all of this FTA stuff. I've been reading a lot about this "auto roll". I'll be honest, I don't exactly know what it is. I've gone to ftacentral.com to try to figure it out, but I'm not having any success. Is there some one who can take a moment and explain this to me?
Barkley
Everything seems to be running fine with the current keys:
thanks i had it on the wrong key number
timbhoy
Still trying to find out what reflash means?
timbhoy
Had a picture yesterday morning, then in pm no pic, just scrambled, etc. The key 1: 40 B2 B9 7A C2 C1 53 75 are the keys I have been using for several days. The ones for key 0: 11 64 6B 2E A5 26 ED 7E are the last ones everyone has listed, but using them doesn't give me a picture. I'm travelling in an RV and really would appreciate some new numbers. Thanks
Key1 is Active!! Phuck Key0
Key1: 40 B2 B9 7A C2 C1 53 75 Is active
key 0 has no bearing on encrytion cuz it's not the active key
so ur problem is sumthin else if u double checked the key and r positive it was entered correct then u have other problems
Help0001
Anyone has an autoroll file for Lifetime Ultra to share? Thanks!
Username: Timscarlet
Dayton, Oh Usa
Post Number: 98
www.pantecdvb.com has a lot of new things.
wickedroll
Hey fellows, I've tested Direct tv before for years. I'm in the dishnetword world now, and i've gotten all the right software to do the Autoroll. But when I try to flash my Fortec star lifetime ultra, the Fortecstar STB Updater v3.31 program says " error: the receiver name is not correct" I've tried all the ones in the drop down box. any ideas?
Craig2
Hey Tim... your link doesnt work
"Error 403
The URL you requested has generated a "Forbidden" notice. "
Username: 316duke
Post Number: 16
hey wickedroll just type Lifetime Ultra in that box and it should work
wickedroll
I did, its the same error. I heard that some recievers cannot use a female/female 9 pin cable. I read that some need a 9 pin/usb cable to work. any thougths?
I'm replying to the post about key 1 being the active key. I have the right numbers and still no picture. I've been using the pansat 2500a for two months and each time the numbers change, I put them in and have a picture. You mentioned I must have other problems...where would I even start? I just thought they changed the codes and I needed new ones. Any suggestions? Thanks
french fry
Try a reboot/reset..BACK of receiver,power OFF,wait 2 minutes,power ON,turn to channel 300..I would reinstall BOTH keys if the reboot/reset doesn't work,then do another reboot after installing the keys again.
DISHNET KEYS Current...still working now
Thanks. We did that this afternoon, except for setting it on channel 300. Lo and behold, the darn thing started working again. Didn't do anything different, but thank goodness it's working. I appreciate your reply.
french fry
the channel 300 trick is a well kept secret
why are the adult channels not giving when selected. For 110 and 119. Please Help. What must I do.
porker
Nagra2...gone forever,unless U subscribe.
Alex Novas
Here for keys http://dss.do.nu
Username: Verlanga
Post Number: 7
galavision gone!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
galavision gone!!!!!!!!!!!!!!!!!!!!!!!!!!!111
anybody know if galavision still working!!!!!!!!!!!!!
any body know if galavision still available????????????????????????????????
Can anyone tell me which autoroll works with a "Multistar Maximum 2500". I can't find that make/model posted anywhere. As well, if I load an incorrect autoroll, will it cause my unit to fail working as it is (ie manual entry of key codes).
Thank you.
Great Keys http://dss.do.nu
kingman
please help i have a staelth 2500 a after inputing keys i lose picture in about 10 minutes i tryed the channel 300 trick but works for only 10 minutes
thanks kingman, also are there any nagra 2 fta boxes that will work in the future i think this stealth is history any help would be greatly appreciated
NeeeddHHeellpp
does anyone have the updated keys?? please and thank you!
NeeeddHHeellpp
Nina
Key0= A1 8B 3F 9C 3C 90 94 8F <----7/6
Key1= 40 B2 B9 7A C2 C1 53 75
clouie
does anyone out there know if the big N2 has taken over all the channelssssssssss.. or did they just change the code.. 4pm here in ca...please let me know. it was a good ride ..
sam123456
need new keys please help
Does anyone have the new keys for dish! Thanks!!
KiFF42o
00 A08B3F9C3C90948F
01 3FB2B97AC2C15375
Username: Maple_leaf
Post Number: 480
Key00= A1 8B 3F 9C 3C 90 94 8F
Post Number: 481
kiff42o wrong keys and you know it.
litlle ceasar
thank you nina!!!!
thank you thank you!
thanks
Thanks NINA
KiFF42o
used autoroll and mine is working,thats all i kno,sorry
SPACECOWBOY
Key 0 A0 8B 3F 9C 3C 90 94 8F SPACECOWBOY
MUNECO
KEY 0: A0 8B 3F 9C 3C 90 94 8F
KEY 1: 3F B2 B9 7A C2 C1 53 75
Nagra2
porker
U so wrong dude nag2 worthless dish wasted all the time and money card sharing works well so far and hack soon 2 follow
Nagra2
porker
Username: Salvatore316
Post Number: 12
ok, why is everyone screwing with the numbers for key 1, is it 3fb2b97ac2c15375 like kiff420 said and then somone else writes that it's wrong. What gives, is he trying to screw everyone up?????????????? What are the correct number keys because everybody is changing letters around and its sooo confusing.
guj
I put keys and still not working says scmbled or bad channel what shoul i do? is a nagravision still working?
chicago
07-06-05 07:00pm EST
Key0: A1 8B 3F 9C 3C 90 94 8F ** Active
These are current and working keys...do a reboot/reset (BACK of receiver,power OFF,wait 2 minutes,power ON,go to channel 300) AFTER changing the keys..
chicago
BTW..a reboot/reset should always be tried whenever U have any problems..
Lastest Keys http://dss.do.nu
Username: Oakcliff
STILL DON'T GET THE reboot/reset
Username: Neomatrixx
Hey what happen to all the adult entertainment channels on Dish network, all thats left is Spanish-Play' ' channel. Is there away bring back the other channels?
Post Number: 13
no, believe me I tried. Get use to buying it on DVD's or learn the Spanish lanuage for Spanish-plaboy. I hate that Nagra 2 code.
Username: Anai
TX United States
NO ANDA POR AQUI PATRICIA, PARA VER SI LA CLAVE COINCIDE??? NO VE SU POST AQUI!!
Username: J_yogi
Wpg, Mb Can
Post Number: 14
Thank you very much everyone
Key 0 A1 8B 3F 9C 3C 90 94 8F WORKS
Cheers
Yogi
saddsfrasfd
Latest Keys are here http://dss.do.nu
mastirlink
how do i install the autoroll/program guide on a pansat 2500; or can't this be done????
poi_dog
My pansat won't switch to the radio channels. It just happened today. Anyone have similar problem?
WTM
Al7bar(.)tk FTA
CHECK US OUT WE HAVE CRACKED NAGRAVISON 2 ALL PpORN CHANNELS WIDE OPEN AGAIN NOBODY PHUCKS DN BETTER THAN US !!
chicago
Sounds like you are a newbie listening to the sales pitch of blacklist and TDG...don't believe it ,its not true and a TDG sales scam to keep buying FTA's. Everyone wants to make all the $$$ they can before N2 is complete.
Latest keys @ http://dss.do.nu
anyone have the new keys?
never mind found them on different website
they are
Key1= C4 82 37 AA 5B C2 2D E5 <--Active
Username: Tulip
01 - C4 82 37 AA 5B C2 2D E5
the new keys Active 01 C4 82 37 AA 5B C2 2D E5
TCM
What site?
Thanks tulip :-)
don't have a name
that key doesn't work I've tried the reboot and still nothing on my screen...
mikeybahama
which site did you get the new keys from?
got them off of hashu.com
John Cena
Active 01 C4 82 37 AA 5B C2 2D E5 enjoy ur new keys guys
don't have a name
this key is not working for me i turned the reciever off waited 5 min and still my tv says updating...does the 00 key need to be changed or is it just me
latest keys @ http://dss.do.nu <---bookmark
heart
This site is a scam
Post Number: 483
Leave then.
Thill1951
your fcuking mother is a scam you stupid pannty-lickker..go have some fun with your 2nd cousin and let us know if he cried when you are done with him you stupid azzhole..ROTF
Roland P
Hi All, our thoughts and support goes out to all the Brits:
Has any one noticed the channels are slowly disappearing from the current line up?
For instance, all of the cinemax, and most Starz, and a few other.
I dont tink site is a site it works pretty weell and has the latest keys
I dont think site is a site it works pretty weell and has the latest keys
