Hi- I recently had my TV repaired (needed new light engine) and just realized when the repairman put my tv back together... he didn't do it completely correct. You know the multimedia slot on it? Well, the tab is stuck "inside" the TV (therefore I can't use it). Does anyone know how I can "break apart" the TV so I can release the tab?
Panny is 1.5 yrs old - but I don't need the help now... I did some work and got it fixed! :-)
For those that might have encountered the same problem - I pushed in on the top part of the multimedia "flap" and the "tab" came out. The card flap's tab is bent and the front front is warped SLIGHTLY, but it works just fine. :-) (Unforunately, I didn't figure this out until I had the back panel of the TV off!)
I've had my panny for almost two years and i have had to replace the bulb twice. Does anyone know if this can be fixed so that i dont spend so much money on the bulbs or is there a recall that i should know about?
