Forget about the key that shut down every day. Use autoroll bin 245
JCHG
I used yesterday and worked excellent, I didn't waiting for key cause it doing by itself.
If you have any question about it, I will tell you all the steps.
Username: Cancan
Post Number: 7
I installed 269 bin and did a reset to factory setting. But all I get was ECM [xx%] and when it reach 100% it stop for a few second and start that ECM thing again. Can you help?
O2bbigger
I got everything here. very helpfull
Autoroll Info
JCHG
1-download de factory bin http://www.pansatusa.com/download.htm
2-When the second light coming you push download and wait for the restart of the receiver.
3-repeat the second step.
4-download the autoroll x-8500....245 and doing like the second step.
5-Download your channel.
6-Watch TV.
JCHG
Do not forget to put your pansat model in the software like "Pansat 2500A"
JCHG
JCHG
JCHG
I need to know how to install autoroll bin 245.
I have the 2500A Pansat. Please forward the instructions to me.
Thanks.
Thanks.
Thanks.
Thanks.
JCHG
6-Watch TV.
The autoroll bin 245 search for key automatic and you don't need to wait for.
JCHG
6-Watch TV.
Username: Cancan
Post Number: 8
I have a Fortec Lifetime Ultra....
" Forget about the key... " OK... Thanks for the idea, but can you guys be more "friendly" in writing the autoroll procedure ... Step by - please ... What I mean is that you say " download de factory bin " etc... Well on you website http://www.pansatusa.com/download.htm there is no such a thing... Can you please be more specific ? You say - Download channel - what channel ? ... Thanks
"2-When the second light coming " the seccond light where ?
"4-download the autoroll x- 8500....245" ( download from where ? )
5-Download your channel ( what chanenl ? )
"6-Watch TV." I think I can do this :-)
Thanks
Username: Er1013
Post Number: 7
Got the autoroll thing, installed in the system. It appears it is working fine. However, how do I know which sat is 110 and which is 119. Any help appreciated. Thank you.
Username: Er1013
Post Number: 8
Got the autoroll thing, installed in the system. It appears to me that it is working fine. However, how do I know which sat is 110 and which is 119. Any help appreciated. Thank you.
Username: Er1013
Post Number: 8
koool
he is right guys... i got lost .. secong light and autoroll ..where can i find autoroll x-8500 245?
waiting for the specific and easy informaition
thankx
I NEED TO KNOW HOW TO INSTALL AUTOROLL BIN 245
I DONWNLOAD DE FACTORY BIN
I DONT SEE X8500..245
WHAT DO I PUT IN THE BIN SPACE AND THE STB SPACE?
WHERE DO i FIND THE 245 FILE TO PUT IN THE BIN?
Username: Stuce10
yeah guys explain from the begining how to download first on the computer, than on the receiver this will help everybody
thank you
Username: Cablerock
Post Number: 33
New Key Here For Fortec Ultra
New Key
Username: Stuce10
does any one know what is wrong with my receiver, I just received today and I plugged in and it' just says on and keeps ataying the power oni tried to turn on and of and nothing
can any one help. maybe I need to flash it and can eny one tell me how to flas it
PLEASE HELP
Username: Er1013
Post Number: 9
Username: Stuce10
PLEASE HELP
i download from pansatusa.com
on the computer where do find the autoroll 245file
to put in the bin file
JCHG
if someone want the autoroll 245 I can send to you by email all that you need to put your pansat 2500A in work condition.
1-Maket a new email account and tell that email and I will going to send you everything (all the files.
JCHG
ROFL
DO I HEAR SOME ECHO ECHO ECHO ECHO ECHO
i want the autoroll 245 can send to me
my email www.vuthyek@sbcglobal.net
show me step by step
JCHG
I will send you everything in one ZIP File as soon as posible.
JCHG
Username: Stuce10
i need one to JCHG
My e-mail is stuce10@yahoo.com
Username: Stuce10
Post Number: 7
can any body tell me what to put as a STB model
what to put in stb model
stb model for pasat 2500 is key:global
Username: Jeep
Charleston, MO.
to download from pc to pansat 2700a the autoroll file what cable do I need the null or straight thru and do I download the app file only or channel data or boot file
Username: Stuce10
Post Number: 8
OK ANONYMOUS THAT HELPED AND I DOWNLOADED EVERYTHYNG, BUT NOW IT SAYS ON MY RECEIVER (ON)
NOTHING ELSE JUST THE LETTERS (On) IN FRONT OF THE RECEIVER WHAT IS THAT DOES ANY KNOW.
THANK YOU.
Username: Nefilim
I have a (USB to RS232)adapter Io can't download files to the reciver.
It says that i need a software to do so.
Can anybody help?
koool
hey JCHG
can u please send me the ZIP for how to install the Autoroll bin 245?
your40@hotmail.com
thankx
Username: Jeep
Charleston, MO.
Help I have a new pansat 2700a My fist fta I have no second pin to go to I read on here you nead to download autoroll to get the second pin? do I nead to down autoroll to have the second pin and do you use a RS232 null or straight thru? do I download app file or channel date or boot file? PLEASE HELPto download from pc to pansat 2700a the autoroll file what cable do I need the null or straight thru and do I download the app file only or channel data or boot file
JCHG
Hi, I'm ready sent to all of you the zip file, I think that this going to help all of you.
PD.
Sorry for delay and don't worry to ask me anything.
Please send me a autoroll 245. Thanks
JCHG
Mr. datvietnm, where? I need a email for!
Da Nang
its ALL right here for Everyone!..just READ it and follow the path..every autoroll file and how to install...along with much more..NO BS!...all in one thread...it doesn't get any easier than this..
https://www.ecoustics.com/electronics/forum/home-video/129815.html
Username: Vpolo
Hi Guys
Can you send me the step by step procedure to install the autoroll 245.bin and please send me the zip file.
Many Thankks my email is :vpolo77@hotmail.com
Username: Vpolo
vpolo77@hotmail.com
Username: Timscarlet
Dayton, Oh Usa
Post Number: 14
Setting Up FTA Receiver and Dish for Dish Network
Note : This is for the Pansat 2500a receiver. You may have to download a different
flash and downloader if you have a different receiver type.
1. turn off receiver, Connect satellite receiver to PC with RS-232C straight cable (Not Null Modem) or a serial cable with a male to female adaptor.
2. Turn on the power in the back of the satellite receiver. Don't turn on the power button in the front of the receiver.
3. Open the Downloader
4. Click "BIN FILE" and select the (X-8500_2500A_245 ) bin file located in the flash folder. (autoroll flash).
Note: Use the Factory Flash (Pansat 2500A_040607_222_api(N) for basic FTA or if something goes wrong and you need the original flash. Go to www.pansatusa.com for the latest flash for your reveiver.
5. Do not interrupt while downloading. Make sure your Computer says "Download Complete", not just 100%. If you don't get "Download Complete" you have NOT completed the Flash!
6. Press OK after download complete; satellite receiver will reboot by itself.
Do not interrupt satellite receiver until reboot by itself. turn off receiver, hook to tv. turn on. wait for new keys to be find, a few minutes, then watch tv.
TVLIST
Can any of you guys kindly send me the steps and all the bin files that I need to setup autoroll for Fortec Star Lifetime Ultra please? My address is tvlist03@hotmail.com . Thanks very much.
Bosox
Here's how to install and where to get the Fortec autoroll..
[link removed]
Username: Knee_grows_back
Post Number: 265
I agree...don't understand why these fcuking morons don't switch over to the autoroll...it's not very difficult. Maybe they like punching in the code everyday,,,,could be like a fetesh for them...who the fcuk knows, I say they need a life..
Username: Deuce0_0
I installed Auto Roll Bin 245 - Dishnet works okay
but Bev will not, I have a good signal and quality but it just says scrambled or bad channel, keys seem to be right. Can anyone give me a couple of suggestion?
Bosox
RESET the receiver...and PLEASE do NOT ask how...its basically like rebooting a computer...If U don't know how,then give it up...I've posted how to reset 1000x times here...good luck
worse case scenario..reflash/load the autoroll
Bosox
worse case scenario..reflash/reload the autoroll again
Post Number: 304
How was your date Blowsox....
These are the latest firmware for pansat with auto roll.
X-75BL_050314_236cE_api for pansat 2300A
X-85BL_050405_246_api for pansat 2500A
X-85BL2_050330_245_api for pansat 1500A
X-87BL_050315_101_api for pansat 2700A
X-95BL_3032_2005_0405_api for pansat 5000HC
they all autoroll. you don't have to deal with entering key changes again.
download the files free here
http://www.dsscentral.net/cgi-bin/hubblegram/CSUpload.cgi?command=viewupload&database=files%2edb
Username: T202m
Can someone please send me the bin files and instructions for a pansat 2700a receiver, I would like to get the files for bell expressvue and dishnetwork. tom202m@hotmail.com
Thanks.
LK
T202..if U want something then U must go out and seek it...it will not come to you...there are hundereds of links here to DSS sites that have all the file and info U need..here's just 1 site...www.dsscommunity.c o m
sweety
wait do u have to pay in order to DL autoroll?? does n.e one know how to get it for free?--thanx
sweety
LK
ITS FREE!...File Share FTA area at www.dsscommunity.c o m
sweety
oOow ic thanx...i go there and do what?--help plz :-)
LK
IGNORE THE IDIOT KNEEGROW
cIyo
IGNORE KNEEGROW......ITS THE ONLY WAY
