Platinum Member Username: NydasPost Number: 16595 Registered: Jun-06 | Version 212 is out. It is a required non-optional upgrade. for K1 plus k1plus_212_20091111.zip for kbox prodigy k1pro_212_20091111.zip They are not yet available at the currentbins site. |
Bronze Member Username: Kashif786Post Number: 35 Registered: Dec-08 | Did you or any body tested plz post if kbox working after 211.Thanks |
Platinum Member Username: NydasPost Number: 16596 Registered: Jun-06 | https://www.ecoustics.com/electronics/forum/home-video/601718.html See post by Cuppa |
Bronze Member Username: Kashif786Post Number: 36 Registered: Dec-08 | Thanks Nalin. |
Silver Member Username: GrnncPost Number: 127 Registered: Apr-08 | It is working fine.Just loaded with usb and it started working rite away.... |
Bronze Member Username: LoverboyzPost Number: 74 Registered: Aug-06 | Hello everybody. 210, 211 and 212 are worst files I have seen in KBox history. I have dish 1000+ pointed to 119, 118 and 110 with dishpro lnbs. In file 203 i used to get all transponders on 118 using setting universal 9750-10750(please note: I did not get all the channels by using auto scan I had to add some channels manually by using manual scan add missing vertical transponders by subtracting the channel transponder by 24600. i.e if transponder 12033 was missing I would subtract 24600-12033=12567 and I would see good signal and get the missing channels). But now this doesn't work I don't get signal at all. Every time I change channel I would loose the signal of the other transponder, and then when I do manual scan that missing signal channel would come back.. but when change channel again I would loose the other again. Please don't tell me something is wrong with my settings or something is wrong in my wiring.. Because I know it works on files 203 and previous ones.. This is definitely a software issue. It's strange kbox should automatically figure out the missing transponder settings for dish pro lnbs and dish pro dish like nfusion and pansat does. I am not winning but I just wish coders listen to my request and fix this problem. I wish file 203 works because this new files suck bad and it's really frustrating. |
Gold Member Username: Saqeeb9000Post Number: 6263 Registered: Oct-07 | post the same message at dssrookie.com as its the official site.. |
Silver Member Username: KingofdakingzPost Number: 498 Registered: Jun-06 | sada i factory reset n i saw 2 new indian channels there, one is a punjabi tv and another one is colors, but dont work |
Silver Member Username: Pannu16Post Number: 898 Registered: May-06 | John i am havin exactly same problem on 91 nimiq.. everythin was on and now bad or no signal but if i put 203 bin its a good signal.. i have also used the same theory of adding 5 to transponders frequency to get signals and scanned manually.. did ya get any solution yet!! i tried turnin auto TP off but it gets on again and again!! |
Gold Member Username: Saqeeb9000Post Number: 6271 Registered: Oct-07 | lakh those channels are down for long time.. |
Silver Member Username: KingofdakingzPost Number: 499 Registered: Jun-06 | i guess in progress maybe haha, thanks buddy ![]() |
Silver Member Username: Pannu16Post Number: 899 Registered: May-06 | so yup.. put 212 in and then put 203 back and everythin works with no TP problems!! |
New member Username: BhardwajMississauga, Ontario Canada Post Number: 3 Registered: Aug-07 | is it working yet, yes or no loaded the latest file nothing happened, want to know how long to, get it fixed, if anyones knows. |
Platinum Member Username: NydasPost Number: 16615 Registered: Jun-06 | Menu and then in Configuration, do a system reset, including erasing all channels. Use 0 0 0 0 for PIN. Then rescan. Switch off, switch on and wait till connection on (Menu/configuration/network). After that rescan your sats and you will be OK. Don't hurry. Be very patient. |
Bronze Member Username: AbusubhanPost Number: 32 Registered: Sep-07 | Hi, Is KBox down again? I have red light since 7 PM and even thou I have flipped the on/off switch the light remains red. Is anyone else experiencing outage? Thanks |
New member Username: BhardwajMississauga, Ontario Canada Post Number: 8 Registered: Aug-07 | tryed that nothing happened, don't know whats worng wiht it, and when it;s coming back on or it. |
Bronze Member Username: David_2Post Number: 31 Registered: Jan-07 | I have the same problem.. Hub light is still red that means I am not connected |
Platinum Member Username: NydasPost Number: 16616 Registered: Jun-06 | Kbox working fine since setting up earlier today. I just tested a few Indian channels on 118.7 |
Silver Member Username: SumpPost Number: 898 Registered: Aug-09 | there are radom amounts of people down no ryhm or reason and "that's all i have to say about that" |
Gold Member Username: GregrafPost Number: 3878 Registered: Dec-07 | OK Forest |
Silver Member Username: SumpPost Number: 899 Registered: Aug-09 | u da man u get the prize u figured it out .. he he he |
Silver Member Username: Pirate_pete_209Post Number: 103 Registered: Jul-09 | What a Senile old fool.![]() He troll he web for info and now he calls himself a TESTER ![]() |
Silver Member Username: SumpPost Number: 900 Registered: Aug-09 | i've seen that picture before !! |
Bronze Member Username: SafariPost Number: 12 Registered: Dec-08 | Xbox down. Cannot get connected. Was working fine for a day with new file. Says ethernet is not plugged in. Did a reset. Any suggestions Anil |
Bronze Member Username: WhellandPost Number: 34 Registered: Nov-08 | The machine is alive & well on the network... It is pulling down the correct DCHP addresses... I can ping the Kbox... from remote computers... Occasionally there is an error that states: Version 1.62 is available for download... (the download always fails)... I suspect that is where the error exists... |
Gold Member Username: Saqeeb9000Post Number: 6281 Registered: Oct-07 | Nalin Nyda Platinum Member Username: Nydas Post Number: 16616 Registered: Jun-06 Posted on Friday, November 13, 2009 - 10:50 pm: Edit Post Kbox working fine since setting up earlier today. I just tested a few Indian channels on 118.7 nalin some internet companies blocked port 80 i beleive which cause outage for lots of kbox owners, isp's like verizon and sympatio bell that's what i am hearing from people.. |
Bronze Member Username: WhellandPost Number: 35 Registered: Nov-08 | Sada... No ISP's block port 80... Port 80 is http (internet web browsing)... Verizon does not block any ports as a company policy... If KBox now all of a sudden wants to communicate on a different port, wouldn't it be wise to at least inform their customers? It's not a port issue... Their server(s) are not answering the call. |
Gold Member Username: Saqeeb9000Post Number: 6283 Registered: Oct-07 | so yukon what is reason that some kbox rec's are working with certain providers while other's are not working with ... ? |
New member Username: JattmundaPost Number: 2 Registered: Aug-09 | any body know punjabi channel working on kbox pro |
Platinum Member Username: NydasPost Number: 16625 Registered: Jun-06 | No they are not - at least not yesterday. I think ALL Punjabi channels were off. |
