Is there a new bin for captive works
Username: Naz123
Post Number: 29
is there a new bin for captive works 600S premium if there is what site should i get it from and what loader should i use
Username: Dude123
Post Number: 2185
vist [link removed] for latest CW files - NO registration required
Username: Naz123
Post Number: 30
thnx im trying to load them but it is staying a 0%
Username: Dude123
Post Number: 2187
Check you port settings? have you loaded a bin before on you receiver using same computer?
Username: Naz123
Post Number: 31
never done it before
Username: Dude123
Post Number: 2188
are you using lap top? PC?
which cable are you using rs232 or are you trying to load the bin using usb?
Username: Naz123
Post Number: 33
pc and no the bin wire and it is plugged in
Username: Dude123
Post Number: 2190
are you using XP or Vista? goto mycomperter/properties/Divice manger
Username: Naz123
Post Number: 34
xp
Username: Dude123
Post Number: 2192
under device manger you should have com ports and if your wire is plugged in then you should be able to see which comport it is set to...let me know if you can see all that stuff
Username: Naz123
Post Number: 35
i see Communications Port
Username: Dude123
Post Number: 2197
ok and under communications port do you see your cable thats attached to your PC? if you do right click on it and go to properties then under advance settings change your port setting to a desired port and then select the same port on your loader when downloading file.
Username: Rtap
FL
Post Number: 2155
whats up NW hows everything.hope all is well.nz123 for guides and help visit the new home for crazy at http://muft.yoo7.com/index.htm
Username: Naz123
Post Number: 36
no i dont see it
Username: The_coders
Post Number: 1042
wow tappie , thats just crazy !
Username: Dude123
Post Number: 2199
NOthing much RTAP, how is the new home?
Username: Rtap
FL
Post Number: 2156
waiting for you.come visit. all is well it should be completly with info in about 2 to 3 days.come by im there now
Username: Dimwitt
Post Number: 637
www.howtofta.com/captiveworks/cw600s-premium-sw-upgrade-guide/
Username: Dude123
Post Number: 2200
Will do my friend....
Username: Dude123
Post Number: 2201
Nz123
While in the device manager connect and disconnect your cable from PC and see if device manager refreshes and if you notice your cable in there some where because you should be able to see it in the device manager or else your cable is not communicating properly with your PC
Username: Rtap
FL
Post Number: 2157
meet you there
Username: Yoman
Post Number: 99
Yes RTAP is correct, i visited this site..it has awesome support for files and guides..plus one on one chat to discuss your problems?..come check it out?
