yeah you can get star one and star plus on viewsat this is how you do it
Go to menu installation, channel scan, and select Echo 3 TP 12329 H and you will get channel name STARONE as soon as you get it stop your scanning and SAVE IT and its >> Channel 716 StarONE
DO THE SAME THING WITH THIS BUT DIFFERENT TP Echo 3 TP 12411 H scan it and you will get channel name VIDEOITALIAN (something like that) and its Channel 718 Star
if you have 61.5w just write down your antenna settings do factory default adjust antenna settings and do auto scan it will come up on 716 and 718 easiest way of doing it
