Best DAC/Amps for Headphones: Editors’ Choice 2025
Our picks for the best desktop and portable DAC/Amps for audiophiles of 2025 include Burson Audio, JDS Labs, FiiO, iFi Audio and Rotel.
Best DAC/Amps eCoustics Editors Choice 2025
Introduction
The desktop used to be an afterthought in audio. Now it’s prime real estate in the Head-Fi revolution, and consumers are treating it that way. If you’re spending real money on better headphones, you don’t want a wobbly skyscraper of gear swallowing half your workspace. You want a compact DAC and headphone amplifier that actually does the job: clean power, enough gain for everything from hyper-sensitive IEMs to 600-ohm dinosaurs, and formats that don’t age out in six months.
At minimum, that means 24-bit/192kHz and well beyond. For many, it also means DSD support, true single-ended and balanced outputs, and Bluetooth connectivity that isn’t just an afterthought. LDAC and aptX Lossless from phones, Bluetooth transmitters, even modern DAPs—people want all of it without needing an engineering degree or a second mortgage.
The good news? We’re finally there. At least 20 brands now offer desktop DAC/amps that are genuinely excellent—well-built, transparent, powerful, and future-minded. This category has matured fast, and it’s only getting better. The gear got smaller, smarter, and more capable, and suddenly the desktop is where some of the most meaningful progress in personal audio is happening. Long overdue, but absolutely welcome.
Best DAC/Amps of 2025
iFi Zen DAC 3 ($199)
iFi ZEN DAC 3
iFi ZEN DAC 3
First off, the name is a bit misleading—the Zen DAC 3 is a DAC/amp, not a standalone DAC. For $199, buyers get a plug-and-play desktop unit: connect a source via USB, plug in headphones, and you’re off. It also includes RCA outputs for pure-DAC use and supports 32-bit/768kHz PCM, DSD512, and even MQA for those who still care. Its TI Burr-Brown DAC gives it a warmer, more relaxed tone than the usual AKM or ESS crowd, and the XMOS implementation helps push the Burr-Brown architecture further than you’d expect at this price. As a DAC it’s a strong value at $199—add the built-in headphone amp and it becomes an even smarter buy.
Learn more | $199 at Amazon
JDS Labs Element IV ($549)
JDS Labs Element IV DAC/AMP
JDS Labs Element IV
JDS Labs has built its name on precision, consistency, and that minimalist industrial design that makes the gear look as good as it sounds—and the Element IV continues that tradition. Delivering 3.2 watts (10.2Vrms) into 32 ohms, it’s a clear step up from the Element III’s 2.3-watt output, with enough drive to power even heavy hitters like the HiFiMAN HE6se V2. Under the hood, the ESS Sabre ES9018K2M DAC and XMOS XU316 processor handle digital duties, supporting 32-bit/384kHz PCM, DSD128, and ASIO playback. The result is textbook JDS Labs: transparent, neutral, and free from gimmicks—letting your headphones and music speak entirely for themselves.
Go to full review | $549 at JDS Labs
FiiO K15 ($550)
FiiO K15 Desktop DAC and Headphone Amp Front View Angle
FiiO K15
The FiiO K15 is the rare “do-everything” desktop unit that doesn’t come with a luxury-tax price tag. At $550, it delivers DAC, streamer, headphone amp, Bluetooth hub, AirPlay receiver, Roon Ready endpoint, and even analog inputs—including a ground terminal for turntables—in one polished box. The 3.93-inch color touchscreen makes navigation painless, and between the tactile knobs, remote control, and FiiO Control app, it’s one of the most user-friendly all-in-ones in its price bracket. Under the hood, you get dual AKM AK4497S DACs from the VELVET SOUND series, LDAC/aptX HD Bluetooth, full USB DAC functionality (up to 768kHz/32-bit, DSD512, and MQA), plus optical, coaxial, and USB storage playback. In short: every modern input a listener could reasonably want is accounted for.
Power isn’t an afterthought either. The K15 uses a discrete Class A/B amplifier that outputs up to 3,000mW per channel from the balanced jack, giving it enough muscle for high-impedance headphones while remaining quiet and controlled with sensitive IEMs. Connectivity, decoding, UI, and raw capability all hit well above the asking price, making the K15 one of the strongest values in the “one box to rule them all” category. If you’ve been hunting for a single device that can anchor a desktop or living-room system without blowing the budget, this is exactly the kind of do-it-all gear that makes you wonder why everything else is so expensive.
Learn more | $599 at Amazon
Burson Playmate 3 ($599)
Burson Playmate 3 DAC/Amp
Burson Playmate 3
The Burson Playmate 3 is one of the most complete all-in-one desktop solutions in the sub-$600 category, bringing serious horsepower and flexibility to a segment usually full of compromises. At $599, it combines an ESS9039 DAC (768kHz / DSD512), a remote-controlled preamp, and a 3W Class-A headphone amp built on the same design DNA as the flagship Conductor GT4. The chassis is classic Burson—solid, attractive, and built for easy access to the internals—because the Playmate 3 is fully op-amp-rolling ready. The STANDARD edition ships with NE5532 op-amps, Silent Power 01 modules, and a 24V/3A PSU, but the platform is designed for experimentation. Broad compatibility (USB, optical, RCA, mic input) and support for both desktop (Windows/macOS) and mobile devices make it a real plug-and-play hub.
Performance is where the Playmate 3 earns its keep. The Class A amp idles at 30W and pushes up to 3.5W at 16Ω, 2.5W at 32Ω, and enough current delivery to properly drive high-impedance headphones. Sound quality leans clean, controlled, and spacious—exactly what you expect from a modern ESS implementation paired with Burson’s high-current Max Current Power Supply design. Channel separation hits 128dB, THD stays extremely low, and the unit doubles as a capable preamp for powered speakers or external amps. For listeners who want flagship-level performance, huge tweakability, and real muscle without spending GT4 money, the Playmate 3 is easily one of the strongest values in the desktop DAC/amp space.
Go to full review | $599 at Apos Audio
Rotel DX-3 ($1,699)
Rotel DX-3 Black Angle Front Lifestyle with Headphones
Rotel DX-3
The Rotel DX-3 is a true all-in-one desktop powerhouse—part DAC, part headphone amp, part preamp—built to handle everything from sensitive IEMs to power-hungry planars. Supporting 32-bit/384kHz PCM, DSD256, and Bluetooth aptX HD, it offers exceptional digital flexibility alongside serious muscle: 2.8W @ 16Ω (balanced) and 150mW @ 300Ω (balanced). Connections include 4.4mm balanced, 6.35mm single-ended, RCA, and XLR outputs, letting it run headphones or powered monitors with ease. Inside, a custom toroidal transformer anchors the design, ensuring low noise and rock-solid reliability. With its intuitive controls, smart display dimming, and tank-like build, the DX-3 delivers the clean, transparent performance Rotel is known for—minus the desktop clutter.
Go to full review | $1,699 at Crutchfield
iFi iDSD Valkyrie ($1,699)
iFi iDSD Valkyrie Portable DAC Amplifier
iFi iDSD Valkyrie
The iFi iDSD Valkyrie is a transportable Bluetooth DAC/amp built for power junkies who refuse to compromise on sound. Weighing nearly a kilo, it’s packed with four Burr-Brown DSD1793 DACs, support for PCM 768kHz, DSD512, and even xMEMS earphones, pushing up to 28V peak-to-peak or a claimed 5.7W into 32 ohms. Real-world power aside, it delivers stunning dynamics, holographic imaging, and clarity few portable units can touch. Add aptX Lossless, LDAC, XBass II, XSpace, and a massive 20,000mAh battery offering 18 hours of playback, and you’ve got a high-end DAC/amp built for anywhere listening—just not your pocket. Pricey and bulky, yes, but the Valkyrie’s sound and versatility make it a portable reference rig for those who demand the best.
$1,699 at Audio46
Burson Audio Conductor GT4 ($3,399)
The Burson Conductor GT4 (Deluxe Version) is a no-nonsense, Class-A DAC/amp powerhouse from Melbourne that delivers 10 watts per channel into 16 ohms with dual ESS Sabre ES9038Q2M DACs and Burson’s flagship V7 Vivid opamps. It supports PCM up to 768kHz, native DSD512, and Bluetooth LDAC/aptX HD, powered by six ultra-low-noise MAX Current Power Supplies for black backgrounds and explosive dynamics. Built from solid CNC-machined aluminum and weighing 5kg, it runs hot—literally—but offers unmatched control and transparency with even the toughest headphones, like the HiFiMAN HE6se V2. Brutally powerful, upgradeable, and built to outlast trends, the GT4 proves that finesse and firepower can coexist—just keep your fingers off the heat sinks.
Go to full review | $3,399 at Apos Audio
The Bottom Line
This group shows just how far the desktop category has come and why it’s become ground zero for the Head-Fi crowd. JDS Labs’ Element IV remains the clean, American-made benchmark for sane money, delivering real power, real measurements, and zero nonsense. FiiO’s K15 takes the opposite approach, stuffing every modern feature you could want into a compact chassis without turning your desk into a data-center rack. Burson’s Playmate 3 brings the brand’s trademark muscle and Class A attitude to the party, while Rotel’s DX-3 feels like the moment traditional hi-fi finally admitted the desktop matters.
And if you want the “forget about upgrading for a decade” option, Burson’s Conductor GT4 sits at the top like a smug heavyweight champ. Different personalities, different price points, but the through-line is obvious: the desktop DAC/amp is no longer a compromise — it’s the smartest investment most headphone listeners can make right now.
2 Comments
2 Comments
  1. fishman
    December 8, 2025 at 9:45 pm
    I have both the FiiO K15 and Topping DX5II and the dx5ii is better all-around with more detail and more oomph, especially in the lower end. The soundstage is also wider and with better imaging over the K15. Both of them can power my HiFiman Arya Stealth well but the DX5II just does a better job. Just my two cents.
    • Ian White
      December 8, 2025 at 10:05 pm
      Fishman,
      Glad you enjoy it. I just invested in some Topping gear for review purposes. Slightly older models from 2024 but I needed more options when reviewing.
      IW
Eversolo's $1,280 DAC-R8 packs proprietary R2R conversion and serious DSP, while its $1,880 C10 promises precision clocking. Is the extra box worth it?
Our picks for the best IEMs of 2025 include Beyerdynamic, Melody Wings, Campfire, 64 Audio, HiSenior and UE Pro.
From affordable USB-C adapters to premium balanced DACs and versatile Bluetooth hybrids, our 2026 Editors' Choice picks reveal which portable DAC/headphone amplifiers are worth...
Our favorite Dongle DACs in 2025 for audiophiles include models from Questyle, Audioengine, iFi and Campfire Audio.
I stream, you stream, here are our choices for the best video streaming devices of 2025.
Check out our favorite wired over-ear open-back and closed-back headphones for audiophiles and studio professionals at various price points.
Our favorite integrated amplifiers for audiophiles in 2025 includes models from WiiM, Advance Paris, Moon by Simaudio, Quad and Marantz.
Shopping for wireless noise cancelling over-ear headphones in 2025? Here are our picks for the best you can buy on any budget.
