Tivoli Audio Unveils Model One Digital Generation 3 Tabletop Radio With Support for Spotify Connect
Tivoli’s 3rd generation tabletop radio blends real wood design with Wi-Fi, Bluetooth, AirPlay 2, Google Cast, Spotify Connect, and hi-res sound for $349.
Tivoli Audio Model One Generation 3 Tabletop Radio in Walnut and Gold
Tivoli Audio isn’t just leaning on nostalgia anymore—it’s doubling down on relevance. The new Model One Digital Generation 3 takes the company’s signature mix of real wood cabinetry and aluminum hardware and bolts on modern essentials: AirPlay 2, Google Cast, Spotify Connect, FM/DAB, Bluetooth, and Wi-Fi streaming that actually works without a headache.
Think of it as a radio that refuses to die quietly—it adapts, updates itself via firmware, and still gives you the tactile pleasure of a dial instead of a soulless touchscreen.
Coming off our recent positive experience with the Tivoli SongBook MAX and the still-classic Model One BT (our review drops Thursday), it’s clear Tivoli isn’t just dabbling—they’re quietly building one of the smartest retro-modern ecosystems on the market.
model-one-gen-3-white
Tivoli Audio Model One Digital Generation 3 (white)
Their products hit that sweet spot of affordable, great-sounding, and thoughtfully designed—with just enough personality thanks to color finishes and collaborations that don’t feel like cheap gimmicks.
They’re perfect for the places where a big-box wireless speaker feels oversized or out of place: the kitchen counter, a nightstand, the bathroom, the spare bedroom at the cottage, even the garage or deck when you want Sunday pre-game on without dragging out a full system (yes, especially when the Bills are about to humble the Jets).
People also like that Tivoli products still feel like objects, not disposable tech—you turn a knob, twist a dial, push a button. It’s why my SongBook MAX on the kitchen counter in Florida gets more play than some of my “serious” rigs. The new Model One Digital Generation 3 fits right into that ethos—streamlined, tactile, and smart enough for modern life, even if DAB is basically a ghost in North America.
model-one-gen-3-black-hand
Tivoli Audio Model One Digital Generation 3 (black)
How to Set Up and Stream with Tivoli Audio Model One Digital Gen 3: AirPlay 2, Google Cast, TIDAL Connect, and Spotify Connect
Getting the Model One Digital Generation 3 onto Wi-Fi isn’t hard, but you need to know the rules. Tivoli makes you grab the free Tivoli Audio Setup app from the App Store or Google Play. For Android users, it’s mandatory—no app, no Wi-Fi. Apple users get it a little easier, but you’ll still need the app if you want Google Cast active.
Here’s the process, stripped of the usual fluff:
  1. Install the Tivoli Audio Setup App. Make sure your phone or tablet is on the same Wi-Fi network you plan to use.
  2. Power on the speaker. Tap the Power/Source/Volume knob to turn it on, and switch sources until you see “Wi-Fi” on the display. If it doesn’t drop into setup mode, press the Wi-Fi button on the back.
  3. Use the app to connect. Open the Tivoli app, tap +Add, and follow the prompts. Once connected, the display will confirm.
  4. Activate Google Cast. After Wi-Fi is locked in, the app will ask if you want to enable Cast. Say yes, unless you plan to ignore Google Home entirely. Your speaker will then show up under “Local Devices” in the Google Home app.
  5. For iOS and AirPlay 2: Head to Wi-Fi Settings → Set Up New AirPlay Speaker → choose Tivoli Audio M1D3_XXXXXX. Rename it (trust me, you’ll thank yourself later) and set a password if you want. Done. Now it shows up in Control Center → AirPlay menu.
Once that’s sorted, streaming is seamless. Spotify ConnectTIDAL Connect, and any Google Cast-enabled app just need you to pick the Model One Digital from the device list. With AirPlay 2, pull up Control Center, hold the audio card, tap AirPlay, and fire away.
No drama, no learning curve—just a clean setup, a retro dial to keep you grounded, and all the modern streaming hooks built in.
model-one-gen-3-rear-white
Tivoli Model One Digital Generation 3 — Key Specifications
  • General
    • Dimensions: 4.5 x 8.7 x 5.5 in (H x W x D)
    • Weight: 3.4 lb
    • Cabinet: Real wood veneer with aluminum hardware
    • Available Finishes: Three grill and wood veneer combinations
  • Audio
    • Rear-ported cabinet design
    • Class AB amplifier
    • Full-range driver for room-filling sound
    • 56-bit DSP processing
    • 24-bit stereo audio ADC/DAC
    • High-resolution lossless audio streaming
    • Standard: 44.1 kHz / 16-bit (CD quality)
    • Hi-Res: Up to 48 kHz / 24-bit or higher
  • Connectivity
    • Wi-Fi with AirPlay 2 and Google Cast built-in
  • Spotify Connect and Tidal Connect
    • Bluetooth® wireless
    • 3.5 mm auxiliary input
  • Radio
    • FM radio
    • DAB+ (in supported markets)
  • Other Features
    • Alarm clock function
    • Automatic firmware updates
    • Intuitive rotating ring and single-knob control
    • Full-featured remote control
model-one-gen-3-front-walnut
The Bottom Line
The Tivoli Audio Model One Digital Gen 3 nails the balance of form and function—real wood, aluminum, and a tactile design that will look at home in many scenarios. With support for AirPlay 2, Google Cast, Spotify Connect, and TIDAL Connect, plus FM/DAB, Bluetooth, and aux-in, it covers every way you’d want to stream. At $349 USD, it’s not cheap, but the combination of timeless design, modern tech, and daily usability makes it one of the smartest values in the Wi-Fi speaker space.
Where to buy: $349.99 at Tivoli Audio (available mid October 2025)
QUAD ESL 2912X Electrostatic Speaker System at AXPONA 2026
Quad ESL 2912X electrostatic speakers at AXPONA 2026 from MoFi Distribution prove big panels can deliver clarity, scale, and real emotional connection without excess.
Amphion Stereo System AXPONA 2026 Amphion Stereo System AXPONA 2026
Amphion Argon7LX arrives at AXPONA 2026 with Finnish precision, clean power, and zero drama. No hype, just sound that quietly outperforms.
ATC EL50 Anniversary Active Speakers at AXPONA 2026 ATC EL50 Anniversary Active Speakers at AXPONA 2026
ATC EL50 debuts at AXPONA 2026 for $99,999. Does this active 3-way tower justify the price or fall short where it matters?
Geshelli TORC DAC at AXPONA 2026 Geshelli TORC DAC at AXPONA 2026
Geshelli's TORC DAC makes its case at AXPONA 2026 with a modular design, swappable DAC boards, and a real upgrade path that will not...
2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood 2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood
Dynaudio Legend bookshelf speakers hit AXPONA 2026 with Esotar 3 tweeter, real bass, and Danish build that proves the internet got this one wrong.
2026 Grado Phono Cartridges 2026 Grado Phono Cartridges
Grado updates its phono cartridge lineup with refined stylus, OCC copper coils, and improved designs across Lineage, Timbre, and Prestige series.
Spotify finally builds a high-end Listening Lounge to showcase lossless audio, but after years of delay what exactly took so long to take sound...
Spotify adds Exclusive Mode for bit perfect desktop audio playback. Does this mean Spotify Lossless now rivals Apple Music, TIDAL, and Qobuz for sound...
Spotify is raising prices across Premium plans, now ranging from $6.99 to $21.99. Is the added cost justified, and who really benefits?
A year-end look at the biggest consumer A/V and media stories of 2025, from streaming wars and AI to vinyl, TV tech, and high-end...
The Tivoli SongBook MAX is retro, loud, and weirdly addictive. Mid-century design meets Miami volume—your neighbors may never forgive you.
Movies
High-end audio, wireless headphone chaos, Spotify’s fake “lossless,” and Hollywood’s latest implosion — from Taylor Swift’s box office reign to Marvel’s flops, the dogs...
Upgraded for 2025 in new colors with better sound and longer battery life, the Tivoli Audio PAL BT portable Bluetooth speaker and FM radio...
