Knowles isn’t just some random parts supplier—they’re a heavyweight in the world of precision audio components. From high-end capacitors and RF filters to surgical-grade microphones and those tiny-but-mighty balanced armature (BA) drivers found in serious IEMs, they’ve been quietly powering the gear you didn’t know you relied on.
The Knowles x Status Audio Situation
So here we are again—another pair of wireless earbuds. But this time, Status Audio didn’t just crank out a generic TWS clone. They tapped Knowles for their well-regarded balanced armature drivers and built something that actually tries to push the format forward. The new Status Audio Pro X wireless earbuds pack a triple-driver hybrid setup—two Knowles BAs and a single dynamic driver per side. That’s a rare combo in this price bracket, let alone from a brand still flying under the radar.
The goal? Clear, detailed sound that punches through the Bluetooth fog and gives some of the big-name hybrid TWS contenders a reason to sweat. Whether the world needed another pair of earbuds is debatable—but these at least make a compelling case for their existence.
A balanced armature driver works by sending an electrical signal through a coil that moves a tiny reed suspended between two magnets—hence the “balanced” part. This motion drives a stiff aluminum diaphragm, which then creates sound. Because the diaphragm doesn’t suffer from the same resonances you get with typical dynamic drivers, the result is more focused, precise audio—especially in the mid and high frequencies. It’s a tiny setup with serious sonic intent.
Status Audio Levels Up with Pro X: Triple-Driver Tech and Knowles Precision
With the market flooded by wireless earbuds—many claiming “hi-res” credentials—consumers have gotten pickier. Rightfully so. The bar’s been raised, and brands that want to stay relevant have to do more than slap on a trendy codec and call it a day.
That’s where the Status Audio and Knowles partnership gets interesting. The Pro X isn’t just another TWS with a fancy name—it’s built around a hybrid driver design that actually makes a difference. Two Knowles balanced armature drivers handle the precision work, while a 12mm dynamic driver brings the low-end muscle. It’s a system built to handle nuance and impact, something most single-driver earbuds can’t quite manage.
Users get some flexibility too, with EQ options including the default Status Signature and the Knowles Curve, which is based on research into real-world listening preferences. Turns out, most people—regardless of age or hearing sensitivity—respond better to extended treble above 10 kHz. The Pro X leans into that, delivering high-frequency detail without tipping into harshness.
Bottom line: Knowles’ BA tech gives the Pro X the edge it needs to stand out. You get crisp highs, textured mids, and a low-end that doesn’t smear everything else. It’s a rare case of the spec sheet translating into actual listening benefits.
From Jon Kiachian, President of MedTech and Specialty Audio at Knowles Corporation: “Our BAs represent the pinnacle of miniaturized audio engineering …The collaboration with Status Audio exemplifies how our BA drivers can help innovative brands deliver truly exceptional audio experiences in remarkably compact form factors. The Status Pro X showcases exactly what becomes possible when cutting-edge driver technology meets thoughtful product design—an audio experience that reveals all the nuances and details of music that conventional earbuds simply cannot reproduce.”
Knowles’ balanced armature drivers aren’t just about sound quality—they’re about smart packaging. Their compact design allows Status Audio to shrink the Pro X by 21 percent compared to its previous model, all without sacrificing performance. You still get the full frequency range, solid battery life, and clear, dynamic audio.
And because these BA drivers are highly sensitive, they also open the door for better hearing personalization. Whether you’re tweaking EQ or using onboard hearing profiles, the Pro X makes the most of every milliwatt—delivering more detail while sipping power. It’s a win for both your ears and your battery meter.
From James Bertuzzi, Status Audio CEO: “When designing the Pro X, we needed a technology partner that could help us deliver on our promise of uncompromising audio quality in a more compact form,….Knowles BA drivers were the clear choice, allowing us to achieve frequency response and detail that would be impossible with conventional dynamic drivers alone. The combination results in a listening experience that truly differentiates the Pro X in today’s crowded earbud market.”
What You Get with the Status Audio Pro X Wireless Earbuds: Features, Fit, and Performance
Building on the foundation laid by the Between Pro and Between 3ANC, the new Pro X pushes the Status Audio design language forward. It’s slimmer, lighter, and more ergonomic, making it easier to wear for long sessions without the constant urge to readjust. But it’s not just about comfort—under the hood, there’s real evolution happening.
Beyond the Knowles/dynamic driver hybrid setup, the Pro X brings a refreshed app experience, stronger connectivity, and support for next-gen audio codecs—some of which are industry firsts in this category. While the full spec sheet is still under wraps until the planned September launch, everything so far suggests that Status Audio didn’t just iterate—they actually innovated.
Status Audio Pro X – Key Features
- Hybrid triple-driver acoustic system
- 12mm dynamic driver
- Dual Knowles balanced armature drivers
- Hybrid active noise cancellation
- Adjustable transparency (“ambient-aware”) mode
- AI-powered Voiceloom speech enhancement for clear phone calls
- Bluetooth 5.3 with LE Audio and Auracast support
- Supports SBC, AAC, LDAC, and LC3 codecs
- High-Resolution Wireless Audio certified by the Japan Audio Society
- Google Fast Pair and Microsoft Swift Pair support
- Multipoint connectivity (connect to two devices at once)
- IP55 water and dust resistance
- Up to 8 hours of playback on a single charge
- Up to 24 hours total battery life with charging case
The Bottom Line
Status Audio isn’t reinventing the wheel by using balanced armature drivers—others have done that—but combining them with hi-res Bluetooth codecs, Google Fast Pair and Microsoft Swift Pair, plus solid IP55 water and dust resistance, all for $249, definitely puts the Pro X in the conversation. Feature-wise, it ticks all the right boxes for anyone serious about wireless earbuds without selling a kidney. The real question, though, is how they sound. Because all the tech in the world means nothing if the music doesn’t deliver. Stay tuned—these earbuds promise a lot, but only a proper listen will prove if they truly rise above the crowded pack.
Price & Availability
The Status Audio Pro X wireless earbuds are available via Status Audio for $199 in Black Alloy or Moonbeam White.
Related Reading
- Best True Wireless Earbuds: Editors’ Choice
- Noble Van Gogh IEM: Four-Driver Hybrid Meets Starry Night—No Two Look the Same (Good Luck Picking!)
- FiiO’s FA19 Flagship IEMs Feature 10 Balanced Armature Drivers
- FiiO’s FX17 Flagship IEMs Integrate Electrostatic, Dynamic, and BA Drivers
